Facing Issue On Design Example: Intel Arria 10 FPGA Remote System Update via PCI Express*
Hi
I am trying to emulate the Design Example: Intel Arria 10 FPGA Remote System Update via PCI Express*. i am facing issue when we trying to download any application
can anyone help me on this?
Steps Followed by me
Step. 1 : Load Mater_Image jic file through onboard blaster - Success
Step 2: Reboot the dvk - Success - Four LED glows
Step 3: Copy driver, Install & run the driver - Success
Step 4: download application - Facing issue(PFA)
Flash Device ID: 1021bb20
Step1 : Do you want to download the application image to FLASH?
(Please input 'y' or 'n' to select, and press ENTER to go on):y
Step2 : Please input start and end address of application image downloaded to FLASH.
(You could get below information from *.map file, and input here.)
(Warning: Please use start address 0x0 if you are downloading factory image!!!)
START ADDRESS :0x04000000
END ADDRESS :0x5568FFF
Step3 : PLease input program file directory.
(For example: /home/rsu_over_pcie/user/ru_auto.rpd)
/home/jetson/GRL_C2V/A10_Flash/vel_image/app2c_auto.rpd
Info : Download application image into Flash, file size is 22450176 Bytes, start address is 0x4000000
Erasing EPCQ flash ...
################################################## 100%
Writing EPCQ flash ...
Reading back data from Flash ...
Warning : Flash data error at addr 0xc000000, expected data is 0x3a, but read data is 0x0
Warning : Checking stop due to read back data error
Step4 : Do you want to reconfig FPGA?
Note: I am able perform Step4 (reconfig) With initial configuration(loaded using onboard blaster). Yes, able to reconfig different application
@Ryan_M_Intel
Thanks for the example design.
- NurAiman_M_Intel
- I noticed from all your previuos reply, all the details were tested using Page_4 address.
Have you try to program Page_0 and Page 1? Are they success?
Page_0 0x00000020 0x01569FFF (0x0156958B)
Page_1 0x02000000 0x03568FFF (0x03568F27)
Page_2 0x04000000 0x05568FFF (0x05568F27)
2.On top of that, at step 4, did you press Y? If yes, did the FPGA able to boot up and work as intended?
Aiman
- MIT_R_D
@NurAiman_M_Intel
1. Have you try to program Page_0 and Page 1? Are they success?
Yes, We try to program Page_0 and Page 1; its not success
No, When we program Page_0 or Page_1 or Page_2 through PCIe, FPGA did not boot up
- NurAiman_M_Intel
Can you please try again by following below:
[1] Erase the flash using Quartus Programmer.
[2] Restart the flow by generating the JIC file with image 0, image 1 and image 2 in it and then program it into the flash.
(Follow page 8 in the document)
[3] generate the rpd file for image 2, then try again to update the image using terminal
(follow page 18 - section 3.7.2)
Aiman
- NurAiman_M_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
