17 years agoExternal SRAM Timing Problems
Hi all,
I work on a task of porting NiosII Softcore processor, JTAG UART, SRAM, FLASH, ON-CHIP along with a Tri-State Bridge in Cyclone III(EP3C25F324C8). I had the program compiled sucessfully and on running a simple Hello-World program it says the popular error using cable "usb-blaster [usb-0]", device 1, instance 0x00pausing target processor: ok
reading system id at address 0x08002f40: verified
initializing cpu cache (if present)
ok
downloading 05000000 ( 0%)
downloaded 62kb in 1.0s (62.0kb/s)
verifying 05000000 ( 0%)
verify failed between address 0x5000000 and 0x500f79b
leaving target processor paused
But I am able to run a Hello_World program from on-chip memory. Where am I going wrong? Is it in the SRAM's Timing? Should i do anything with Tsu and Tco requirements in the Assignments editor? Many thanks...
1 Reply
In your SOPC_builder,you could find which device's address is include 0x5000000 and 0x500F79B,then you can surely about which device is going wrong.
[/B][/B]
