Ionela's avatar
Ionela
5 years ago
Event no 119751
I'm Ionela Hagighiol ,SQE from Flex, Romania and we have the below issue with this part manufactured by you.
Please advise how to proceed further.
Component details:
Material PN
ALC3-1AB310260004_REP
Material Description
ICFPGA5SGXMA7N2F45I3NStratix5B
Material SN or Lot Nr
N/A
Date Code or Part Mark
1607
Supplier Name
ARROW ASIA DISTRIBUTION GBR
Supplier PN/MPN
5SGXMA7N2F45I3N
  1. Problem description: Rx SM BIP8 Error Count on L1CH2 during prechamber ramp-up from -5°C to 50°C
  1. Detected by: Customer field failure, failure confirmed by factory tests
  1. Quantity Affected: 1 PCS
  1. Failure Message: SM BIP8 Error Count on L1CH2 on PM
  1. Flex or Nokia analysis:
This unit failed in field at customer. At Flex factory tests it failed with Rx SM BIP8 Error Count on L1CH2 during prechamber ramp-up from -5°C to 50°C. The suspected component for the issue was Obelix component (ALC3-1AB310260004_REP) and was sent to be replaced. With the new component the unit passed tests. Obelix component to be sent to supplier to re-run tests and find root cause of failure.
Replacing the component solved the problem and card passed factory tests.
  • Hi Ionela,
    Thank you for using Intel Community Forum.
    The case will be continued support through email as confidential info is required.
    Thanks!
    Wani
1 Reply
  • Zawani_M_Intel's avatar
    Zawani_M_Intel
    Hi Ionela,
    Thanks!
    Wani
