16 years agoerrors occur when I use ddr controller IP
everybody. I use DDR IP in my design. first, I create a new project and set a blank .bdf as top entity. Then, I use plug_in manager create a DDR control. In my .bdf file, I import the PLL and the DDR controller symbol. then compile the project. but , quartus 9 give the following errors: //==================================================== Error: Post compile timing analysis failed (retcode=1) Info: The most likely cause of this type of error is: Info: (1) Some signals on the local-side interface are not connected causing logic to be optimised away, Info: This script requires that the complete logic for the specified width of the datapath (both read and write paths) be present in the design. Info: (2) The clear-text HDL files for the datapath may have been modified. Info: (3) Not all clocks from the system pll are global. Error: Output clocks to SDRAM Not Found Error: Output clocks to SDRAM Not Found Error: In-System timing verification of DDR/DDR2-SDRAM Megacore variation 'DDRip' could not be completed due to the above errors. Error: Evaluation of Tcl script auto_verify_ddr_timing.tcl unsuccessful Error: Quartus II Shell was unsuccessful. 5 errors, 0 warnings Error: Peak virtual memory: 55 megabytes Error: Processing ended: Thu Jun 10 10:43:46 2010 Error: Elapsed time: 00:00:03 Error: Total CPU time (on all processors): 00:00:02 Error: Quartus II Full Compilation was unsuccessful. 7 errors, 121 warnings1 Reply
