13 years ago
Error:Connected system timestamp not found on target at expected base address.
I'm fairly new to FPGA programming, please bear with me.
I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board.
I basically followed these procedures:
1) Generate the SOPC which includes the Jtag Uart
2) add all files into the quartus II project and compile
3) Programme the board
4) Create a project including the application and bsp
5) Build the project
6) Run the project as Nios II hardware
Then it gives me the error:connected system id hash not found on target at expected base address
I tried to follow the posts from the forum and ignored the mismatch in Systemid and System timestamp. Then it gives me: downloading elf process failed.
If I click System ID Properties I get:
Expected system ID base address: 0x0 (as in SOPC)
Expected system ID:0x0
connected system id: not found
Expected system timestamp:1343399230 (as in SOPC)
connected system timestamp: not found
May I know what are the possible issues?
Any suggestions would be much appreciated .
    I download the same program into another FPGA board , it runs OK. Is it possible the fpga is broken?
    --- Quote Start ---
    In your SOPC the cpu reset_n input is not connected. I've attached a screenshot of a SOPC. May be this helps you.
    --- Quote End ---
    I download the same program into another FPGA board , it runs OK. So I think the program is right.Is it possible the fpga is broken or other reason?
