14 years agoError:Connected system timestamp not found on target at expected base address.
Hi, I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed the...
9 years ago --- Quote Start --- In your SOPC the cpu reset_n input is not connected. I've attached a screenshot of a SOPC. May be this helps you. --- Quote End --- I download the same program into another FPGA board , it runs OK. So I think the program is right.Is it possible the fpga is broken or other reason?
