Error with Ethernet Design
I followed the instruction from the course "10/100/1000 Mb Ethernet Design with Altera Transceiver Devices: Introduction (OTSE1116)", and I got this error:
Error: System.altera_ethernet_1: altera_ethernet_1.receive and eth_mon_inst_1.avalon_streaming_sink must be on the same clock domain, since they're connected.
Can anyone tell me how to fix it? :D7 Replies
i don't think the two problems are related, you've moved past the multiplier problem to an on chip RAM problem. you can see the hierarchy path is different
i don't know a lot about the TSE Ethernet core, but i would open it up and try and decrease the buffer sizes to use less on chip RAM as you can see, the CIVGX15 is a very small device - Altera_Forum
Seems like it's too small for the multipliers to be embedded in memory blocks :)
I changed the Hardware multiplication type to Logic Elements, and I got this error:
:DError: Selected device has 60 RAM location(s) of type M9K. However, the current design needs more than 60 to successfully fit Info: List of RAM cells constrained to M9K locations Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_en" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_err" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_en" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_err" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" - Altera_Forum
open up the Nios in Qsys and change the Hardware multiplication type to Logic Elements or None
the smallest CIVGX doesn't have hardware multiplier blocks for some reason - Altera_Forum
Recreate the project from begining only using this project as reference.
Yeah, I changed the clock and that worked. Now I got these errors:
I guess the original project made for Stratix IV, but I changed the device setting to Cyclone IV in Qsys and Quartus. I am not sure if it is the reason for these errors, and I don't know how to fix. :DError: The design contains 2 blocks of type "Embedded multiplier block" but the selected device EP4CGX15BF14C8 does not support such blocks Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_1|mult_add_gkr2:auto_generated|ded_mult_e091:ded_mult1|mac_mult2. Implement the design block using soft logic by choosing the relevant option in the related megafunction Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_2|mult_add_ikr2:auto_generated|ded_mult_e091:ded_mult1|mac_mult2. Implement the design block using soft logic by choosing the relevant option in the related megafunction Error: The design contains 2 blocks of type "Embedded multiplier output" but the selected device EP4CGX15BF14C8 does not support such blocks Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_1|mult_add_gkr2:auto_generated|ded_mult_e091:ded_mult1|mac_out3. Implement the design block using soft logic by choosing the relevant option in the related megafunction Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_2|mult_add_ikr2:auto_generated|ded_mult_e091:ded_mult1|mac_out3. Implement the design block using soft logic by choosing the relevant option in the related megafunction - Altera_Forum
Yes, connect both clock inputs to the same clock.
