16 years ago
error when compiling
hi why is my altera coding is error when coding
no waveform output..
is it something that i am missing from my project??
i only defined the VHD file
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 9.0 Build 235 06/17/2009 Service Pack 2 SJ Web Edition
Info: Processing started: Sun Aug 15 05:08:11 2010
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off micop -c micop
Info: Found 2 design units, including 1 entities, in source file seg7.vhd
Info: Found design unit 1: SEG7-display
Info: Found entity 1: seg7
Error: Top-level design entity "micop" is undefined
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 212 megabytes
Error: Processing ended: Sun Aug 15 05:08:15 2010
Error: Elapsed time: 00:00:04
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings
any1 can help me??
    If your project has many files it is good to right click on the top level file and execute the "set as top level" command.
    This eliminates problems if you changed the name of the file that contains the top level.
    Dude,
    your toplevel name must be same name of your file, for example, if mine file name is micop.v the code have to be like:
    module micop (input x, output y);
    assign x = y;
    endmodule
    By
    Full Altera in Brazil
    If your project is called micop, your toplevel need to have the same name.
    Whether it is HDL or schematic, make sure your toplevel also has the name micop.
    Success, Ton
