16 years agoerror when compiling
hi why is my altera coding is error when coding no waveform output.. is it something that i am missing from my project?? i only defined the VHD file Info: *******************************...
16 years agoIf your project has many files it is good to right click on the top level file and execute the "set as top level" command.
This eliminates problems if you changed the name of the file that contains the top level.
