Junmo's avatar
Junmo
4 years ago
Error coccured during modelsim simulation
I have training board with a cyclone II device. so I have to use quartus II 13.0 sp1 sw.
I installed the sw, and coded the circuit using verilog HDL.
But during simulation in VWF , the above error occured.
In quartus II 18.1 VWF simulation with same circuit, this error message didn't show.
Also, reinstalled 13.0 sp1. But it doesn't work.
I found question about this error message in this forum.
But anyone doesn't give answer.
Please help me..
  • I have yet to receive any response from you in regards to my last reply.
    With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Richard Tan
    p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
  • Any reason you want to continue using the Quartus 13.1?
    Since you do not see the error on Quartus 18.1, I would recommend to upgrade the design to the latest Quartus standard 21.1 as it is more stable.
  • KennyT_altera's avatar
    KennyT_altera
    Also, what device that you were using? If you still see the problem in Q21.1std, you may send us the design to validate.
    KennyT_altera
    Any reason that you cannot use modelsim? VWF is an old simulator where we might have some bug on this.
    Our recommendation is to use the latest Quartus 21.1std as the software is a lot stable.
  • Junmo's avatar
    Junmo
    Thanks for your response.
    I read that solution.
    Unfortunately, I couldn't fix error.
    the solution suggested doesn't work.
    Anyway, Thanks again.
