12 years agoerror 10170: HDL syntax error in Verilog
Hi, i got some trouble for the code i developed:
when i execute this code: if(rst==1'b1) begin 38. cs [0] = 4'b0; 39. cs [1] = 4'b0; 40. cs [2] = 4'b0; 41. cs [3] = 4'b0; 42. cs [4] = 4'b0; 43. s [5] = 4'b0; end then compile and i got that syntax: Error (10170): Verilog HDL syntax error at digitalclock.v(39) near text "="; expecting ".", or an identifier Error (10170): Verilog HDL syntax error at digitalclock.v(40) near text "="; expecting ".", or an identifier Error (10170): Verilog HDL syntax error at digitalclock.v(41) near text "="; expecting ".", or an identifier Error (10170): Verilog HDL syntax error at digitalclock.v(42) near text "="; expecting ".", or an identifier Error (10170): Verilog HDL syntax error at digitalclock.v(43) near text "="; expecting ".", or an identifier please note line 38! please help me solved this error, thank you! :)3 Replies
I solved that error! :)
we should declare always(posedge...) instead of always (edge...) in Verilog. :) - Altera_Forum
Using 2014 version of Quartus II software (web edition), I have problem compiling the following code receiving error 10170.
Error received: Error (10170): Verilog HDL syntax error at shifter16.v(2) near text "input"; expecting ";" Any help would be appreciated.module shifter16 (A, H_sel, H) input A; input H_sel; output H; reg H; always @ (A or H_sel) begin if (H_sel) H={A,1'b0}; else H={A,A}; end endmodule - Altera_Forum
it quite easy, you shoud declare "module shifter16(A,H_sel,H);" not "module shifter16 (A, H_sel, H)"
to complete a command line include module declareation, you must use ";" :)
