SUHAS_KRISHNA
5 months agoError : Arria 10 emif_reset_ interrupt acknowledge
Hi All, I am currently working with an Arria 10 FPGA on a custom board and have encountered an issue where the PCB restarts after the following error message appears: "Error: Arria 10 EMIF reset in...
AdzimZM_Altera
5 months agoHi SUHAS_KRISHNA,
I would suggest to check the DDR component with the EMIF Example Design.
You may refer to user guide to generate the example design from the link: https://docs.altera.com/r/docs/683842/21.1/external-memory-interfaces-arria-10-fpga-ip-design-example-user-guide/generating-the-synthesizable-emif-design-example
Please enable the EMIF Debug Toolkit as following instruction to check the calibration details of the DDR: https://docs.altera.com/r/docs/683106/current/configuring-your-emif-ip-for-use-with-the-debug-toolkit
Adzim
