Kalyan
18 days agoEPM7064LI44-15 – Xeltek SuperPro 610P Program OK but Verify fails at address 0x50
Hello, I am trying to program an existing design on an Altera EPM7064LI44-15, PLCC44. The device is the original non-JTAG EPM7064LI44-15. I understand that this device requires an older parallel pr...
FakhrulA_altera
12 days agoHello Kalyan,
Thank you for the details.
The log shows “ID checks error. Ignore.” before programming and verification. Therefore, “Program OK” does not confirm successful programming; the device ID or programming algorithm does not match the detected device.
Please:
- Do not ignore the ID-check error.
- Run Xeltek’s insertion/contact test and confirm device orientation.
- Update the SuperPro software, firmware, and device library.
- Ask Xeltek to confirm that the selected EPM7064@PLCC44 algorithm and SA244 adapter explicitly support EPM7064LI44-15.
If the mismatch remains, please provide Xeltek with the detected/expected ID values (A7/0F), algorithm date, and verify failure at 0x50. Since this is a third-party programmer algorithm issue, Xeltek is best positioned to provide the corrected algorithm.
Thank you.
Fakhrul
