16 years ago
epcs controller
I'm trying some informations about EPCS CONTROLLER control word.
Inside datasheet doesn't speak about meaning of single bit inside EPCS control words.
Somebody knows this bits? I don't understand why altera hide this bits .
I have to use it because I have SPI host that must program epcs and I don't use NIOS II inside FPGA but I use just only spi_slave_to_avalon_mm_master_bridge
So host microcontroller have to control EPCS controller and I need to know single bit meaning.
Somebody can help me?
Bye
G
    Hi Hippo,
    my configuration is different. I have:1
    MPU HOST (as SPI master) connected with FPGA (here SPI as slave: spi_slave_to_avalon_mm_master_bridge). FPGA is connected as ACTIVE SERIAL and I have to program EPCS with HOST MPU.
    This is my problem. Hardware is done and I haven't other possibilities.
    For this reason I would to know how EPCS CONTROLLER run and control word bit's meaning.
    In my idea I HAVE TO REALIZE (HOST SOFTWARE):
    1. use SOF2FLASH to convert .sof into .flash (S-record)
    2. write .flash inside HOST flash (by remote control)
    3. software to convert .flash to SPI PHYSICAL LAYER for spi_slave_to_avalon_mm_master_bridge with commands for EPCS CONTROLLER
    Can You tell me something about point 3?
    I have some difficult to find correct use of EPC CONTROLLER.
    Bye
    Hi Ferraro,
    EPCS is like a regular SPI flash of STmicro. EPCS controller is a Altera SPI controller and a hidden onchip memory.
    So your configuration might look like this,
    MPU ->FPGA[ bridge -> avalon MM bus ->Altera SPI master-> ] EPCS
    Right?
    - Hippo
    Hi Amilcar, can You send me an axample with ASMI?
    My problem is: I have to write EPCSand my microcontroller HOST is connecte with FPGA ALTERA with SPI to avalon master bridge.
    I have to write EPCS. Do You have an example?
    For MSchmitt: thanks but I haven't to program EPCS directly with SPI HOST. I have HOST connected with FPGA and FPGA have to write EPCS.
    Bye
    G
    even the HAL does not tell everything about the epcs controller, normaly you would think okay that epcs device is an SPI memoy so lets have a look at the possible manufacture datesheets to lern more about it.
    but there is something between this spi functionality and the epcs related pins specially that you cannot add a simple custom spi functionality. it seems to be possible now with cyclone III, but i haven't tryed that
