16 years agoepcs controller
I'm trying some informations about EPCS CONTROLLER control word. Inside datasheet doesn't speak about meaning of single bit inside EPCS control words. Somebody knows this bits? I don't understa...
16 years agoHi Hippo,
my configuration is different. I have:1 MPU HOST (as SPI master) connected with FPGA (here SPI as slave: spi_slave_to_avalon_mm_master_bridge). FPGA is connected as ACTIVE SERIAL and I have to program EPCS with HOST MPU. This is my problem. Hardware is done and I haven't other possibilities. For this reason I would to know how EPCS CONTROLLER run and control word bit's meaning. In my idea I HAVE TO REALIZE (HOST SOFTWARE): 1. use SOF2FLASH to convert .sof into .flash (S-record) 2. write .flash inside HOST flash (by remote control) 3. software to convert .flash to SPI PHYSICAL LAYER for spi_slave_to_avalon_mm_master_bridge with commands for EPCS CONTROLLER Can You tell me something about point 3? I have some difficult to find correct use of EPC CONTROLLER. Bye
