14 years ago
Downloading ELF Process failed!
under the nios ii eds command shell:
nios2-download test.elf
Using cable "USB_Blaster [USB-0]",device 1,instance 0x00
Processor is already paused
Initializing CPU cache <if present>
OK
Downloaded 327KB in 5.6s <58.3KB/s>
Verifying 05100000(0%)
Verify failed between address 0x5100000 and 0x510FFFF
Leaving target processor paused.
in the qsys builder,0x5100000~0x51FFFFF is onchip memory.
why Verify failed?
help! thanks!
    do you have a jtag uart in your project and is the IDE opening a terminal to it?
    I still did not solve the problem.
    I checked the pins, clock and reset_n, both is correct. The reset is conected to the KEY_0 (normally high) or I can direct to a signal with '1' level signal
    My system has: cpu, onchip-mem, sysid, jtag, dm9000a.
    Both resect and exception vectors are setting to on-chip mem (20 KB).
    @Romerson : No problem, your processor is only "paused". You have to init/reset your board
    Guys, I have this problem:
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Pausing target processor: OK
    Reading System ID at address 0x00011020: verified
    Initializing CPU cache (if present)
    OK
    Downloading 00008000 ( 0%)
    Downloaded 8KB in 0.1s
    Verifying 00008000 ( 0%)
    Verified OK
    I have a DE2 and I'm tryng to use de DM9000A Ethernet controller (using a custom component in SoPC), with Quartus and NIOS 7.2 version. I'm using an on-chip mem and not a flash. There is not error about pins. This address 00008000 is the first of mem on-chip.
    Do you have suggestions?
    Is it a custom hardware configuration? Is it properly constrained and does it meet timing requirements?
