14 years agoDownloading ELF Process failed!
under the nios ii eds command shell: # ############################# nios2-download test.elf Using cable "USB_Blaster [USB-0]",device 1,instance 0x00 Processor is already paused Initial...
14 years agoI still did not solve the problem.
I checked the pins, clock and reset_n, both is correct. The reset is conected to the KEY_0 (normally high) or I can direct to a signal with '1' level signal My system has: cpu, onchip-mem, sysid, jtag, dm9000a. Both resect and exception vectors are setting to on-chip mem (20 KB).
