14 years agoDownloading ELF Process failed!
under the nios ii eds command shell: # ############################# nios2-download test.elf Using cable "USB_Blaster [USB-0]",device 1,instance 0x00 Processor is already paused Initial...
14 years agoGuys, I have this problem:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00011020: verified Initializing CPU cache (if present) OK Downloading 00008000 ( 0%) Downloaded 8KB in 0.1s Verifying 00008000 ( 0%) Verified OK Leaving target processor paused I have a DE2 and I'm tryng to use de DM9000A Ethernet controller (using a custom component in SoPC), with Quartus and NIOS 7.2 version. I'm using an on-chip mem and not a flash. There is not error about pins. This address 00008000 is the first of mem on-chip. Do you have suggestions?
