14 years agoDownloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 .
My user chip is CycloneII EP2C35FC8 , when my sopc builder use Pll、SDRAM、FLASH、MCU、JTAG , I can run as hardware of holld_world . (Eclipse - Application and BSP from Template) But , when I return sopc builder and add EnthModule、DMA(*2-RX、TX)、 onchip momery(4096bytes)、timer . And Auto-Assign Base Addres、IRQS. Compilation after , I run as web_server_socket(rgmii) (Eclipse - Application and BSP from Template) , but message tell me , downloading elf process failed .
So , I try again run as holld_world , but message still tell me downloading elf process failed . Would like to ask anyone encountered a similar problem : ( ?
Dear Daixiwen
My project of software at the \Myweb_server_bsp\drivers\src indeed have altera_avalon_tse.c , and inside file , indeed have support about 88E1111 message . But I still not understand , my led indicate denormal of reason . (LED_LINK1000 Right , LED_LIN100 Unright...) And about MDIO communication problem, I not understand your mean.. - Altera_Forum
Dear Daixiwen
LED indicate is solve (normal : LED_RX、LED_DUPLEX、LED_LINK100) Because the problem from my pin planner of voltage config . (need set to 2.5V Level) But NiosII message still tell meerror : mac group[0] - no phy connected!
error : phy[0.0] - no phy connected!speed=100,duplex=full MDIO communication ... I will try : )
Dear Daixiwen
I can catch PHY!! indeed is hardware of MDIO problem . Now NiosII message tell me Your Enthenet MAC address is 00:07:ed:ff:3d:e5 prepped 1 interface , initalzing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x05002000 INFO : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation , checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED. MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established , restart auto-negotiation... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100 , Duplex = Full OK , x=0 , CMD_CONFIG=0x00000000 MAC post-initalization : CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 0.0.0.0 But...now I still not Catch IP ... and LED message indicate is not denormal. (LED_TX unright) I try of de2-115 board test web_server_socket , and function is normal. (LED_TX right) so ... I exclude Internet cable problem of possibility ... I think maybe is my TX_DATA Problem... - Altera_Forum
This line
--- Quote Start --- IP address of et1 : 0.0.0.0 --- Quote End --- shows that your board isn't getting an IP. Try to set a static IP address in the code yourself or use a DHCP server. - Altera_Forum
Dear Daixiwen
I setting static IP address of file simple_socket_server.h but TX_LED just bright look and unright...and I try use super terminal , but still not connect ... (I have set SSS_PORT) - Altera_Forum
Do you see the correct address in the nios console? If not it means the Interniche Stack isn't picking up the IP address you set.
You should try and use a sniffer such as Wireshark to see if the board is answering any ARP requests. - Altera_Forum
I have solved the problem by locking the address of all the components in the NIOS II processer! This problem confused me several days. At last, I remove it!
