14 years agoDownloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 . My user chip is CycloneII EP2C35FC8 , when my sopc builder use Pll、SDRAM、FLASH、MCU、JTAG , I can run...
14 years agoDo you see the correct address in the nios console? If not it means the Interniche Stack isn't picking up the IP address you set.
You should try and use a sniffer such as Wireshark to see if the board is answering any ARP requests.
