Does altering the FPGA IO standard actually change something in hardware?
- 6 months ago
VCCIO if powering the IO banks of the IO , depending of where the IO is located.
eg. If you power VCCIO -> 3.3V, the IO standard located in that IO bank should be 3.3V based IO.
The IO assignment in Quartus pin planner must be aligned with the physical setup on your board.regards,
Farabi
I believe I already explained here that the problem isn't related to IO-Standards rather than inappropriate clock source.
(134) Does altering the FPGA IO standard actually change something in hardware? | Forum for Electronics
You are specifically asking if changing the IO-Standard affects input signal processing. Short answer is, as long as you don't activate Schmitt Trigger or use a completely different IO type (e.g. voltage referenced or differential), it does not. Input threshold is a partly affected by actual bank voltage but less than proportianal for MAX10 series according to datasheet.
An IOE description beyond the details given in Device Manual isn't publically available, I fear.
Regards Frank
- ElShang7 months ago
Kindly thanks for your reply.
It never hurts to ask a question at multiple resources. :-)
- FvM7 months ago
Right, this is the best place to ask Altera FPGA related questions.
- Farabi_Altera6 months ago
Farabi
- ElShang6 months ago
Yes, I've got that already. :-)
The only thing I needed was the unambiguous answer to the question in the heading of the topic. Something like "Yes, there are some setup in the hardware, but we won't tell which exactly. Use the software!". :-D
Thanks!
