13 years agodivide by two operation in vhdl
Hai,
I have write vhdl code for divide by two operation. Below is the short code:
SRL16_a:process(CLK) begin -- SRL16
if CLK'event and CLK='1' then
if en='1' and (cycle=0 or cycle=2 or cycle=4 or cycle=6) then
sr16<=di & sr16(0 to 14); -- shift SRL16
end if;
end if;
end process;
a1<= sr16(ad1); -- output from SRL16
SM_B:process(clk,rst)
begin
if RST = '1' then
di <= (others => '0');
bp <= (others => '0');
bm <= (others => '0');
elsif CLK = '1' and CLK'event then
if en = '1' then
if d_signed =0 then
di<=unsigned(DATA_IN) - unsigned( a1_2);
else
di<= DATA_IN;
end if;
add_temp<=SXT(di,9)+a1;
bp<='0'& add_temp(8 downto 1);
bm<=SXT(di,9)-a1;
end if;
end if;
end process;
I try to add to numbers (di & a1), and then divide the sum by 2. When I simulate the testbench code in ModelSim, the values of add_temp and bm is correct. But, the values of bp is wrong (not as manual calculation). I attach the figure. Anyone please help me. Do I make anything wrong?Thank in advance6 Replies
Hai FvM,
Thanks a lot for your explanation. I learn new thing about logic shift and arithmetic shift here. Appreciate your helps. Thank you :) - Altera_Forum
--- Quote Start --- Then, bp: -50/2=-25. And so on. Please correct me. --- Quote End --- -25 would be 0x1e7. Due to logic shift right, you get 0x0e7 instead, or 231. For arithmetic shift, writebp <= add_temp(8) & add_temp(8 downto 1); - Altera_Forum
--- Quote Start --- According to my manual calculation, the bp values are as expectable. You are doing a logical shift right, probably you want an arithmetical shift with sign extension? --- Quote End --- Hai FvM, Is it the bp values are exceptable? In my manual calculation (I take one example), add_temp:108+(-25)=83. Then, bp: 83/2=41.5. From the waveform, it seems correct. But, the next values is it should be, add_temp: -25+(-25)=-50. Then, bp: -50/2=-25. And so on. Please correct me. Thank in advance - Altera_Forum
--- Quote Start --- Hi , Your simulation shows that a1 dosent become valid for 08 clock cycles . If you can send me the complete VHDL files plus test bench i can take out some bugs . Regards , --- Quote End --- Hai FPGA_guru011, I will send to your e-mail. Hope you can helps. Thanks in advance - Altera_Forum
Hi ,
