13 years agodivide by two operation in vhdl
Hai, I have write vhdl code for divide by two operation. Below is the short code:
SRL16_a:process(CLK) begin -- SRL16
if CLK'event and CLK='1' then
13 years ago --- Quote Start --- Hi , Your simulation shows that a1 dosent become valid for 08 clock cycles . If you can send me the complete VHDL files plus test bench i can take out some bugs . Regards , --- Quote End --- Hai FPGA_guru011, I will send to your e-mail. Hope you can helps. Thanks in advance
