15 years ago
Direct Memory Access (DMA)
hello, i am having a problem with using dma. my dma seems like never finish the transaction because it cannot call the done function and keep on looping in the while(!rx_done). I dont know why. can anyone please help? i posted a lot on the forum but seem like no one is helping. thanks!
my code:
--- Quote Start ---
# include <stdio.h># include <stdlib.h># include <stddef.h># include <string.h># include <system.h># include <io.h># include <alt_types.h># include "sys/alt_dma.h"# include "sys/alt_dma_dev.h"# include "sys/alt_cache.h"# include "sys/alt_alarm.h"# include "alt_types.h"
static volatile int rx_done = 0;
* Callback function that obtains notification that the data
* is received.
static void done (void* handle, void* data)
rx_done++;
int main (int argc, char* argv[], char* envp[])
int rc,i;
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
void* tx_data = (void*) SDRAM_BASE+0x200000; /* pointer to data to send */
void* rx_buffer = (void*) SDRAM_BASE+0x201000; /* pointer to rx buffer */
for(i=0;i<1024;i++)
IOWR(tx_data, i, i);
for(i=0;i<1024;i++)
printf("%d\n", IORD(tx_data, i));
/* Create the transmit channel */
if ((txchan = alt_dma_txchan_open(DMA_NAME)) == NULL)
printf ("Failed to open transmit channel\n");
exit (1);
/* Create the receive channel */
if ((rxchan = alt_dma_rxchan_open(DMA_NAME)) == NULL)
printf ("Failed to open receive channel\n");
exit (1);
/* Post the transmit request */
if ((rc = alt_dma_txchan_send (txchan,
tx_data,
128,
NULL,
NULL)) < 0)
printf ("Failed to post transmit request, reason = %i\n", rc);
exit (1);
/* Post the receive request */
if ((rc = alt_dma_rxchan_prepare (rxchan,
rx_buffer,
128,
done,
NULL)) < 0)
printf ("Failed to post read request, reason = %i\n", rc);
exit (1);
/* wait for transfer to complete */
while (!rx_done);
printf ("Transfer successful!\n");
return 0;
--- Quote End ---
    Hi, I have a question here. I tried to use DMA to transfer data within the same SDRAM, src = SDRAM + 0x200000 and dst = SDRAM_BASE + 0x300000. However, the data in the src and dst is different after transmission. the receive channel seems like cannot write into dst.
    If you have a data cache on the CPU it's possible that the start and/or destination block are cached, and therefore the CPU reads and writes data from it's cache rather than the SDRAM. You have several ways around this:[list]
    [*]Disable the data cache, or use the Nios II/e core
    [*]Do a cache flush on the source block before the dma transfer, and a cache invalidate on the destination block after
    [*]Bypass the cache when accessing the source and destination block, either though the IORD/IOWR macros, or by modifying the pointers with alt_remap_uncached()[/list]
    could anyone repost the picture bigger? or write what are the names of those components?
