Digital clock using verilog HDL
I need to design a clock using 7 segment with stop watch and alarm in Verilog HDL language. As I am new in these HDL I can not find any solution. Can anyone help me to do that? Eraesh12 Replies
Here, check this out.It is working and downloadable onto fpga.
http://www.youtube.com/watch?v=c8v1nfz1zn8 - Altera_Forum
Nani..If i were you, I would have first got into understanding how numbers are represented using the 7-segment. Decimal to 7-segment conversion.
You might need to go through the hardware details for 7-segment displays on your board to understand if they are active HIGH/LOW (i.e. need to find if it is 0 or a 1 that activates each segment). If you get this part, then you got very little to do further. Just maybe a check to see if you have reached a 9 so that you could start counting the next display. It is simpler than you would think. Also a good reference would be the 7-segment code available in the TRDB-D5M sample project available on Altera website. Hope it helps! Regards BP.. - Altera_Forum
ashishkaps gave you some very good suggestions to start. Why don't you try them and come back if you have more questions?
i want to make a program that displays 0000 0001 0002 to 9999. i do not know how to carry over the 0009 to 0010. thank you for all your responses. :)
Your digit1,digit2,digit3,digit4 are single bit registers they can store 0 or 1 but you are trying to increment it from binary values 0 to 9.
use reg [3:0] digit1 and so on to hold a binary value of 9 or 1001. one more thing use digit1==4'b1001 or 4'd9 as the condition instead of 9 after you change the declarations for digits. Yes addign to what DAIXIWEN said the current status of the code might increase the digit values in all 4 block wrt to the clk . If you want to increase the digit value when timer ==16000000 then it should be something like this if (timer==16000000) digit1<=digit1+1'b1; this is not exactly what you should write but to make you understand when you should increase the digit1 value. for your digit2 block it should be something like this always @ (posedge clk) begin if (rst==0) begin digit2<=0; end else if(c1==1'b1) begin digit2<=digit2+1'b1; end else begin digit2<=digit2; end assign c2=(c1 && (digit2==4'd9)); and if its the same code you are implementing you have to write begin -end for the always block too. like always @(..) begin if(..) begin .. end else begin .. end end //for always block begin and yes the specs are not clear to me its a rough code i have written which are subjected to changes so be clear with what you are doing - Altera_Forum
I'm not a verilog specialist, but for starters, I think there is a problem with your first digit.
If I understand correctly, you want to increase the digit by one each time your timer value resets (i.e. every 16000000 clock cycles). But you only do this test when the digit is 9. Furthermore you never put back the c1 signal at '0' so your other digits will increase on each clock cycle after that. You should do it this way: [list][*]first test if reset is enabled, and in that case put the digit at 0 [*]else test if the timer is equal to your maximum value (or any fixed value in fact, you could use 0) and only then, do the following:[list][*]if the digit is 9, put it at 0 and assert the c1 signal[*]in the other cases, increase it by 1 and de-assert the c1 signal[/list][*]if the timer isn't equal to your fixed value, de-assert the c1 signal[/list] - Altera_Forum
i have here the codes. but when i program the fpga, it displays 8888 only. it doesn't count. it was stationary.
module clock (clk, rst, m1, m2, m3, m4, a, b, c, d, e, f, g, dp); input clk, rst; output m1, m2, m3, m4; output a, b, c, d, e, f, g, dp; reg[23:0] timer; reg[19:0] state; reg[7:0] number, disp1, disp2, disp3, disp4; reg c1, c2, c3, c4, digit1, digit2, digit3, digit4; assign m1=digit1; assign m2=digit2; assign m3=digit3; assign m4=digit4; assign{a, b, c, d, e, f, g}=number; assign dp=1; parameter number1=7'b1001111; parameter number2=7'b0010010; parameter number3=7'b0000110; parameter number4=7'b1001100; parameter number5=7'b0100100; parameter number6=7'b0100000; parameter number7=7'b0001111; parameter number8=7'b0000000; parameter number9=7'b0000100; parameter number0=7'b0000001; always @(posedge clk) if (rst==0) state<=4'b0000; else state<=4'b1111; always @ (posedge clk) if (rst==0) timer <=0; else if (timer ==16000000) timer <=0; else timer <= timer+1; always @ (posedge clk) if (rst==0) begin digit1<=0; c1<=0; end else if (digit1==9&&timer==16000000) begin digit1<=0; c1<=1; end else begin digit1<=digit1+1; end always @ (posedge clk) if (rst==0) begin digit2<=0; c2<=0; end else if (digit2==9&&c1) begin digit2<=0; c2<=1; end else begin digit2<=digit2+1; end always @ (posedge clk) if (rst==0) begin digit3<=0; c3<=0; end else if (digit3==9&&c2) begin digit3<=0; c3<=1; end else begin digit3<=digit3+1; end always @ (posedge clk) if (rst==0) begin digit4<=0; c4<=0; end else begin digit4<=digit4+1; end always @(posedge clk) case (digit1) 4'b0000:disp1<=number0; 4'b0001:disp1<=number1; 4'b0010:disp1<=number2; 4'b0011:disp1<=number3; 4'b0100:disp1<=number4; 4'b0101:disp1<=number5; 4'b0110:disp1<=number6; 4'b0111:disp1<=number7; 4'b1000:disp1<=number8; 4'b1001:disp1<=number9; default:disp1<= number0; endcase always @(posedge clk) case (digit2) 4'b0000:disp2<=number0; 4'b0001:disp2<=number1; 4'b0010:disp2<=number2; 4'b0011:disp2<=number3; 4'b0100:disp2<=number4; 4'b0101:disp2<=number5; 4'b0110:disp2<=number6; 4'b0111:disp2<=number7; 4'b1000:disp2<=number8; 4'b1001:disp2<=number9; default:disp2<= number0; endcase always @(posedge clk) case (digit3) 4'b0000:disp3<=number0; 4'b0001:disp3<=number1; 4'b0010:disp3<=number2; 4'b0011:disp3<=number3; 4'b0100:disp3<=number4; 4'b0101:disp3<=number5; 4'b0110:disp3<=number6; 4'b0111:disp3<=number7; 4'b1000:disp3<=number8; 4'b1001:disp3<=number9; default:disp3<= number0; endcase always @(posedge clk) case (digit4) 4'b0000:disp4<=number0; 4'b0001:disp4<=number1; 4'b0010:disp4<=number2; 4'b0011:disp4<=number3; 4'b0100:disp4<=number4; 4'b0101:disp4<=number5; 4'b0110:disp4<=number6; 4'b0111:disp4<=number7; 4'b1000:disp4<=number8; 4'b1001:disp4<=number9; default:disp4<= number0; endcase endmodule **my problem is the increasing of the value of the second digit, and the third and the fourth. what is wrong with my codes.? do i need to use an identifier or any other special codes.? because the ones i used were the only thing i knew. as i have said, i only know basic stuffs. i know i should learn more. please help me. thanks. :) - Altera_Forum
You should handle each digit separately. Have the first digit count from 0 to 9. When you need to go over 9, put it back to 0 and increase the second digit. When that second digit is at 5 and you need to increase it again, put it back to 0 and increase the third digit, etc.
oh, i'm sorry. my problem is i don't know how to separate digital display 1-4 from each other. i can make counter counting from 0000 to 9999 but i don't know how to make it 00:59. also, if it reaches 00:59, how can i make it 01:00.?
we have to display hh:mm and mm:ss when we use the dip switches. thank you for responding. :) - Altera_Forum
Did you even read kaz' answer? He gave tips on how to start. Now if you have a question on a more specific point, we can answer.
