18 years agoDigital clock using verilog HDL
Hi, I need to design a clock using 7 segment with stop watch and alarm in Verilog HDL language. As I am new in these HDL I can not find any solution. Can anyone help me to do that? Eraesh
14 years agoi have here the codes. but when i program the fpga, it displays 8888 only. it doesn't count. it was stationary.
module clock (clk, rst, m1, m2, m3, m4, a, b, c, d, e, f, g, dp); input clk, rst; output m1, m2, m3, m4; output a, b, c, d, e, f, g, dp; reg[23:0] timer; reg[19:0] state; reg[7:0] number, disp1, disp2, disp3, disp4; reg c1, c2, c3, c4, digit1, digit2, digit3, digit4; assign m1=digit1; assign m2=digit2; assign m3=digit3; assign m4=digit4; assign{a, b, c, d, e, f, g}=number; assign dp=1; parameter number1=7'b1001111; parameter number2=7'b0010010; parameter number3=7'b0000110; parameter number4=7'b1001100; parameter number5=7'b0100100; parameter number6=7'b0100000; parameter number7=7'b0001111; parameter number8=7'b0000000; parameter number9=7'b0000100; parameter number0=7'b0000001; always @(posedge clk) if (rst==0) state<=4'b0000; else state<=4'b1111; always @ (posedge clk) if (rst==0) timer <=0; else if (timer ==16000000) timer <=0; else timer <= timer+1; always @ (posedge clk) if (rst==0) begin digit1<=0; c1<=0; end else if (digit1==9&&timer==16000000) begin digit1<=0; c1<=1; end else begin digit1<=digit1+1; end always @ (posedge clk) if (rst==0) begin digit2<=0; c2<=0; end else if (digit2==9&&c1) begin digit2<=0; c2<=1; end else begin digit2<=digit2+1; end always @ (posedge clk) if (rst==0) begin digit3<=0; c3<=0; end else if (digit3==9&&c2) begin digit3<=0; c3<=1; end else begin digit3<=digit3+1; end always @ (posedge clk) if (rst==0) begin digit4<=0; c4<=0; end else begin digit4<=digit4+1; end always @(posedge clk) case (digit1) 4'b0000:disp1<=number0; 4'b0001:disp1<=number1; 4'b0010:disp1<=number2; 4'b0011:disp1<=number3; 4'b0100:disp1<=number4; 4'b0101:disp1<=number5; 4'b0110:disp1<=number6; 4'b0111:disp1<=number7; 4'b1000:disp1<=number8; 4'b1001:disp1<=number9; default:disp1<= number0; endcase always @(posedge clk) case (digit2) 4'b0000:disp2<=number0; 4'b0001:disp2<=number1; 4'b0010:disp2<=number2; 4'b0011:disp2<=number3; 4'b0100:disp2<=number4; 4'b0101:disp2<=number5; 4'b0110:disp2<=number6; 4'b0111:disp2<=number7; 4'b1000:disp2<=number8; 4'b1001:disp2<=number9; default:disp2<= number0; endcase always @(posedge clk) case (digit3) 4'b0000:disp3<=number0; 4'b0001:disp3<=number1; 4'b0010:disp3<=number2; 4'b0011:disp3<=number3; 4'b0100:disp3<=number4; 4'b0101:disp3<=number5; 4'b0110:disp3<=number6; 4'b0111:disp3<=number7; 4'b1000:disp3<=number8; 4'b1001:disp3<=number9; default:disp3<= number0; endcase always @(posedge clk) case (digit4) 4'b0000:disp4<=number0; 4'b0001:disp4<=number1; 4'b0010:disp4<=number2; 4'b0011:disp4<=number3; 4'b0100:disp4<=number4; 4'b0101:disp4<=number5; 4'b0110:disp4<=number6; 4'b0111:disp4<=number7; 4'b1000:disp4<=number8; 4'b1001:disp4<=number9; default:disp4<= number0; endcase endmodule **my problem is the increasing of the value of the second digit, and the third and the fourth. what is wrong with my codes.? do i need to use an identifier or any other special codes.? because the ones i used were the only thing i knew. as i have said, i only know basic stuffs. i know i should learn more. please help me. thanks. :)
