14 years agodifferent style of coding to reduce logic resources??
I need to optimize my design in area. After setting all the required constraints, I started modifying the source code. I made few changes and see some changes in the resource Utilization.
Can anyone please tell me how this has reduced the logic as i dont see much difference in the code other than coding style has change from 1 case to the other. The code is in verilog. case 1: always @(negedge clk or negedge rst_n) begin if ( rst_n == 0 ) begin intr_reg <= 0; intr_core <= 0; end else begin intr_reg <= { intr_reg[0], intr }; intr_core <= ( ((intr_reg == 2'b01) || (intr_core == 1)) && (intr_ack == 0) ); end end endmodule Case 2: resource utilization has reduced by using the ternary operator wire [ 1: 0] intr_wire; assign intr_wire = { intr_wire[0], intr }; assign intr_core1 =( ((intr_reg == 2'b01) || (intr_core == 1)) && (intr_ack == 0)); always @(negedge clk or negedge rst_n) begin if ( rst_n == 0 ) begin intr_reg <= 0; intr_core <= 0; end else begin intr_reg <= intr_wire; intr_core <= intr_core1; end end endmodule can anyone how this type of coding has reduced resource utilization. Thank You7 Replies
--- Quote Start --- My view is that above code will be understood by compiler as r1 is equal to r2 (duplicate) and will end up as one resource wired out as r1,r2. --- Quote End --- Yes, it's an unsuitable test case. - Altera_Forum
--- Quote Start --- Thank You. I still do not see the difference between the two coding styles. In the example below, which is a stripped down example from case 1 and case 2 with the variables renamed, what extra logic is needed for r2 that is not needed for r1, It is my understanding that all RHS operations are combinatorial. wire a; wire b; wire c; reg [1:0] r1; reg [1:0] r2; assign c = { a, b }; always @(negedge clk or negedge rst_n) begin if ( rst_n == 0 ) begin r1 <= 0; r2 <= 0; end else begin r1 <= c; r2 <= { a, b }; end end --- Quote End --- My view is that above code will be understood by compiler as r1 is equal to r2 (duplicate) and will end up as one resource wired out as r1,r2. - Altera_Forum
The actual RHS value for the assignment is evaluated at the clock edge, no logic is generated for the asign statement as such, in so far I don't see a difference between both coding styles.
Which difference do you see in the logic cell count and gate level logic implementation? I'm missing a complete module definition for the code in the first post to check for the claimed differences. - Altera_Forum
Thank You.
I still do not see the difference between the two coding styles. In the example below, which is a stripped down example from case 1 and case 2 with the variables renamed, what extra logic is needed for r2 that is not needed for r1, It is my understanding that all RHS operations are combinatorial. wire a; wire b; wire c; reg [1:0] r1; reg [1:0] r2; assign c = { a, b }; always @(negedge clk or negedge rst_n) begin if ( rst_n == 0 ) begin r1 <= 0; r2 <= 0; end else begin r1 <= c; r2 <= { a, b }; end end - Altera_Forum
Good catch Cris72! I missed that!
Case 2 has NOT the same behavior as case 1.
While the <= assignment inside always block is performed only at clock edges, statement assign intr_wire = { intr_wire[0], intr } is a continuous assignment (I mean combinatorial, clock independent); then you actually get intr_wire = { intr, intr } and a few resources are spared. You should have written: assign intr_wire = { intr_reg[0], intr } - Altera_Forum
I don't really see how this could lead to a lower resource utilization, but you can have a look at the RTL viewer for both synthesises and see if you can find any differences.
