14 years agodifferent style of coding to reduce logic resources??
I need to optimize my design in area. After setting all the required constraints, I started modifying the source code. I made few changes and see some changes in the resource Utilization. Can any...
14 years agoCase 2 has NOT the same behavior as case 1.
While the <= assignment inside always block is performed only at clock edges, statement assign intr_wire = { intr_wire[0], intr } is a continuous assignment (I mean combinatorial, clock independent); then you actually get intr_wire = { intr, intr } and a few resources are spared. You should have written: assign intr_wire = { intr_reg[0], intr }
