MATRIX7878's avatar
MATRIX7878
2 years ago
Designing a FPGA board
I am building my own FPGA board as I cannot find one that has all the abilities that I desire. I want to use an Agilex 7 M-Series (specifically the AGMF039R47A1E1V). I cannot find any CAD files that I can import into Alitum. I have all the peripherals on the board, but no controller or hookups. Where can I find said files so I can know how to connect the FPGA? Also, is there a document about how to wire it up with power (e.g. how should I do the power rails)? Once I get the design done, I will need to code the drivers for my peripherals. I am using DDR5 (x2), PCIe x16 Gen 5 (x1), M.2 NVMe (x1), HDMI (x1) and DisplayPort (x1). Where can I find how to code these. I see IPs, but they seemed incomplete. Where can I find how to code in these protocols?
Thank you,
Drew
  • Hi Drew,
    Good day to you.
    In design example folder, you'll find Verilog files for IPs that you've generated and compiled. Those are the available ones.
    For Hardware, I may suggest you to open up new forum and that'll be direct to the right team.
    Pavee
