Navaneeth's avatar
Navaneeth
3 years ago
Design works in ASE not on FPGA
Our design works in the ASE simulation environment. But it doesn't work on FPGA. Timing constraints are being met.
Please let us know as to what we might be missing / going wrong.
  • Navaneeth's avatar
    Navaneeth
    We haven't received any such errors. The ccip_std_afu is located in the hw/rtl/ccip_std_afu.sv file.
    We're using the streaming-dma-afu BBB as our base design and we've included our files - split.sv and cmm_top.sv ( our matrix multiplier verilog code file ) - in hw/rtl/QSYS_IPS/avst_decimator folder.
  • Nurina's avatar
    Nurina
    I've included the modules in hw/rtl/ but I still see some errors related to it.
    Error(13406): Verilog HDL error at afu.sv(31): object "ccip_avmm_pkg" is not declared
    Error(13406): Verilog HDL error at afu.sv(139): object "CCIP_AVMM_REQUESTOR_DATA_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(139): range must be bounded by constant expressions
    Error(14395): Verilog HDL error at afu.sv(140): CCIP_AVMM_REQUESTOR_WR_ADDR_WIDTH is not a constant
    Error(17457): Verilog HDL error at afu.sv(140): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(142): object "CCIP_AVMM_REQUESTOR_BURST_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(142): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(147): object "CCIP_AVMM_REQUESTOR_DATA_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(147): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(149): object "CCIP_AVMM_REQUESTOR_DATA_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(149): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(150): object "CCIP_AVMM_REQUESTOR_RD_ADDR_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(150): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(153): object "CCIP_AVMM_REQUESTOR_BURST_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(153): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(156): object "CCIP_AVMM_MMIO_DATA_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(156): range must be bounded by constant expressions
    Error(13406): Verilog HDL error at afu.sv(158): object "CCIP_AVMM_MMIO_DATA_WIDTH" is not declared
    Error(17457): Verilog HDL error at afu.sv(158): range must be bounded by constant expressions
    Error(16827): Verilog HDL error at ccip_std_afu.sv(34): cannot open include file cci_mpf_if.vh
    Error(13406): Verilog HDL error at ccip_std_afu.sv(35): object "cci_mpf_csrs_pkg" is not declared
    Received this critical warning:
    Critical Warning(125091): Tcl error: couldn't read file "../../hw/rtl/BBB_ccip_avmm/hw/par/ccip_avmm_addenda.qsf": no such file or directory while executing "source ../../hw/rtl/BBB_ccip_avmm/hw/par/ccip_avmm_addenda.qsf" (file "../hw/afu.qsf" line 6)
    The project I received doesn't have the folder ../../hw/rtl/BBB_ccip_avmm/hw/par/
    Is this required in the project?
    Nurina
    Navaneeth
    Sorry for the delayed response.
    Can you please try with https://drive.google.com/file/d/1K9rg_u6i57mGkBegACfYQz5UjMJiNV8N/view?usp=share_link?
    Steps to run ASE ( after extracting the tar.gz file
    1. cd Capstone-Streaming-DMA-AFU
    2. afu_sim_setup --source=./hw/rtl/filelist.txt build_ase_dir
    3. cd build_ase_dir
    4. make -j16 ( takes around 5 minutes )
    5. two screen sessions are needed
    On first:
    1. make sim -j16
    2. < copy the export path >
    On second:
    1. cd sw
    2. < paste the export path >
    3. make USE_ASE=1
    4. ./fpga_dma_st_test -l on -s 2048 -p 64 -t fixed -f 0
    Steps to run on FPGA:
    2. afu_synth_setup --source=./hw/rtl/filelist.txt build_synth_dir
    3. cp afu_default.qsf build_synth_dir/build/
    4. cp flame-job-script.sh build_synth_dir
    5. cd build_synth_dir
    6. ./flame-job-script.sh ( takes around 2 hours )
    7. fpgaconf streaming_dma_afu.gbs
    8. cd ../sw
    9. make
    10. ./fpga_dma_st_test -l on -s 2048 -p 64 -t fixed -f 0
    Navaneeth M
  • Nurina's avatar
    Nurina
    May I know if you have any updates?
    Nurina
      Navaneeth
      We realised that the FIFO IP was not working when we run on the FPGA.
      So, we used our queues and now we're able to get the results on FPGA.
      Navaneeth M
  • Nurina's avatar
    Nurina
    We do not receive any response from you on the previous reply provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
    Nurina
