Design migration question, Cyclone to Max10, gpio lite related
I am converting a Verilog design from Cyclone IV to Max10.
I noticed that the original Cyclone IV Quartus gpio lite Verilog code for a bidir includes text about the intended chip being a Cyclone IV. When I changed the chip assignment in Quartus to a Max10, there don't seem to be any issues (errors or warnings) about the bidir modules not originally being created for Max 10. Recompilation does not change them.
Do intel gpiolite functions like bidir need to be regenerated when changing from Cyclone to Max10?
- AminT_Intel
The function does not need to be regenerated from Cyclone device to Max 10. I would advise you to double-check on bidir transition, and always verify the pin migration compatibility through Pin Migration View check Migration Capability on your Intel FPGA device like in page 5 from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-v/mv51003.pdf
There is detailed information about Verifying Pin Migration Compatibility on page 44
There is more information about GPIO Lite of Max 10 in page 41 of the same document.
I hope this answer helps.
- FBels
The document link you provided is for Max V, not Max 10, and furthermore ends at page 39.
- AminT_Intel
Thank you for pointing that out! The correct link is https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf
The rest of the page reference is the same as my previous post.
