Design migration question, Cyclone to Max10, gpio lite related
The function does not need to be regenerated from Cyclone device to Max 10. I would advise you to double-check on bidir transition, and always verify the pin migration compatibility through Pin Migration View check Migration Capability on your Intel FPGA device like in page 5 from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-v/mv51003.pdf
There is detailed information about Verifying Pin Migration Compatibility on page 44
There is more information about GPIO Lite of Max 10 in page 41 of the same document.
I hope this answer helps.
The document link you provided is for Max V, not Max 10, and furthermore ends at page 39.
- AminT_Intel5 years ago
Thank you for pointing that out! The correct link is https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf
The rest of the page reference is the same as my previous post.
