12 years agoDesign Environment (Desktop Performance)
FPGA is Big Enough, but the simulation takes too long.
When we try to design with the actual target board, the timing simulation might take pretty long time with bigger logics. Recently, I was being annoyed with the in-built simulator from Quartus. Well, we might stick to poor desktops for the finance issues while we can't be using Modelsim only all the time to match the real behaviours. Would you recommend Some Desktop Specs for better speeds on simulations? CPU? MEMORY Banks with 64-bit OS? or Graphic Card? Which one claims most??2 Replies
Most big FPGA designs don't do timing simulations anymore for this reason. RTL simulations and static timing analysis(TimeQuest) should cover everything.
It was helpful with your comment.
