17 years agoDemultiplexer with latched value
I am using a demultiplexer with six output registers. The code is pretty simple.
process(X,sel)
begin
case sel is
when "000"=>
A <=X;
when "001" =>
B <=X;
when "010" =>
C <=X;
when "011" =>
D <= X;
when "100" =>
E <= X;
when "101" =>
F <= X;
when others =>null;
end case;
end process; I do not reset output regisers since I want to preserve them. That is why I get the following warnings. --- Quote Start --- Warning (10631): VHDL Process Statement warning at demux.vhd(21): inferring latch(es) for signal or variable "C", which holds its previous value in one or more paths through the process --- Quote End --- --- Quote Start --- Warning: Found 9 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew --- Quote End --- Why is wrong to have latched output registers? What do I need to do to remove them?5 Replies
Yeah, you have used the first approach.
--- Quote Start --- Instead, a decoder providing clock-enable signals is preferred. --- Quote End --- - Altera_Forum
parrado wrote:
--- Quote Start --- your VHDL code must assign every signal in order to avoid parasite latches --- Quote End --- It does not have to. As I wrote , I needed to retain the values on each itteration of next register being sent to output. that is why , i could not issue statements such as
It would reset tha value of corresponding output pins to zero, which I don't want. ThanksB<=(others=>'0'); - Altera_Forum
In fact, demultiplexers aren't often used. Instead, a decoder providing clock-enable signals is preferred.
Nevertheless, your VHDL code must assign every signal in order to avoid parasite latches.process(X,sel) begin case sel is when "000"=> A<=X; B<=(others=>'0'); C<=(others=>'0'); D<=(others=>'0'); E<=(others=>'0'); F<=(others=>'0'); when "001" => A<=(others=>'0'); B<=X; C<=(others=>'0'); D<=(others=>'0'); E<=(others=>'0'); F<=(others=>'0'); when "010" => A<=(others=>'0'); B<=(others=>'0'); C<=X; D<=(others=>'0'); E<=(others=>'0'); F<=(others=>'0'); when "011" => A<=(others=>'0'); B<=(others=>'0'); C<=(others=>'0'); D<=X; E<=(others=>'0'); F<=(others=>'0'); when "100" => A<=(others=>'0'); B<=(others=>'0'); C<=(others=>'0'); D<=(others=>'0'); E<=X; F<=(others=>'0'); when "101" => A<=(others=>'0'); B<=(others=>'0'); C<=(others=>'0'); D<=(others=>'0'); E<=(others=>'0'); F<=X; end case; end process; - Altera_Forum
Thanks Uk Fixer. I found a solution added a clock to sensitivity list.
Have a read of http://www.altera.com/literature/hb/qts/qts_qii51007.pdf page 42 it explains why latches are a bad idea. In short FPGAs are built out of storage elements that are all connected to a common clock.
