DE10 Lite setting pins from VErilog RTL
In my design, the GPIOs need to be used to connect to external host (Raspberry PI (aka RPI) in this case).
The GPIOs connector of the DE10 lite will be connected to the RPI connector.
Some are inputs, some are outputs.
I prefer to set the pins assignment from the Verilog file, to allow easier maintenance of the project over time.
Gemini AI suggested to use:
(* location = "PIN_AA13" *) assign gpio_out1 = gpio_out1_int;
Yet the compiler reports:
Warning (10335): Unrecognized synthesis attribute "location" at ../Verilog/MAC_proj.v(142)
Gemini claims I might not be using Quartus Synthesis tool.
Could it be?
How can I check and set it correctly?
Just edit the top-level. And you need to give unique names to inputs vs. outputs (GPIO_IN vs. GPIO_OUT perhaps).
- RichardT_altera
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
- RichardT_altera
I believe all your inquiries has been answered.
Do you have any further question?
Richard Tan
- YigalB1
I think I am all set. Thank you for the good support.
- sstrell
- YigalB1
True, yet in this case I need to modify accordingly the qsf file naming, to maintain the IO mapping.
- RichardT_altera
Could you share the design for the golden top?
You mentioned that the pin is assigned—could you check if it’s assigned through the .qsf file or the RTL? If it’s assigned in the RTL, what does it look like?
Also, what is the exact error message shown by the compiler?
Please paste the error message or provide a screenshot for reference
Richard Tan
- YigalB1
When compiling this:
input [7:0] GPIO,input [15:8] GPIOThe error is:
Error (10134): Verilog HDL Module Declaration error at MAC_proj.v(37): port "GPIO" is declared more than once
About the pins assignment:
You have a good point. I assumed it was done due to naming, yet now I can see the QSF has these names inside.
Here is the golden top:
//=======================================================// This code is generated by Terasic System Builder//=======================================================module DE10_LITE_Golden_Top(//////////// CLOCK //////////input ADC_CLK_10,input MAX10_CLK1_50,input MAX10_CLK2_50,//////////// SDRAM //////////output [12:0] DRAM_ADDR,output [1:0] DRAM_BA,output DRAM_CAS_N,output DRAM_CKE,output DRAM_CLK,output DRAM_CS_N,inout [15:0] DRAM_DQ,output DRAM_LDQM,output DRAM_RAS_N,output DRAM_UDQM,output DRAM_WE_N,//////////// SEG7 //////////output [7:0] HEX0,output [7:0] HEX1,output [7:0] HEX2,output [7:0] HEX3,output [7:0] HEX4,output [7:0] HEX5,//////////// KEY //////////input [1:0] KEY,//////////// LED //////////output [9:0] LEDR,//////////// SW //////////input [9:0] SW,//////////// VGA //////////output [3:0] VGA_B,output [3:0] VGA_G,output VGA_HS,output [3:0] VGA_R,output VGA_VS,//////////// Accelerometer //////////output GSENSOR_CS_N,input [2:1] GSENSOR_INT,output GSENSOR_SCLK,inout GSENSOR_SDI,inout GSENSOR_SDO,//////////// Arduino //////////inout [15:0] ARDUINO_IO,inout ARDUINO_RESET_N,//////////// GPIO, GPIO connect to GPIO Default //////////inout [35:0] GPIO);//=======================================================// REG/WIRE declarations//=======================================================//=======================================================// Structural coding//=======================================================endmodule
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you.
Do you need any further assistance from my side?
Richard Tan
- YigalB1
I think there is a way to control pinout from the RTL source file.
There is a "golden top" within "CD-ROM" download files. All the pins are listed, I assume these are keywords that guide the pin planner.
The problem I faced was with definition of IOs: GPIO[35:0] was defined as INOUT.
When trying to define part of it as Input, and part as output (i.e input GPIO[7:0]; output GPIO[15:8];) the compiler reported error fo double definition of GPIO.
- RichardT_altera
Pin assignment is not possible through RTL.
You need to use 'set_location_assignment' in the .qsf file.
Check the User Guide below for further details.
Alternatively, you could use the Pin Planner tool by go to Assignments > Pin Planner.
Richard Tan
- sstrell
I don't think that's a valid synthesis attribute. You have to store location assignments in the .qsf. This is a list of synthesis attributes: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/hdl/vlog/vlog_file_dir.htm
