When compiling this:
input [7:0] GPIO,
input [15:8] GPIO
The error is:
Error (10134): Verilog HDL Module Declaration error at MAC_proj.v(37): port "GPIO" is declared more than once
About the pins assignment:
You have a good point. I assumed it was done due to naming, yet now I can see the QSF has these names inside.
Here is the golden top:
// This code is generated by Terasic System Builder
module DE10_LITE_Golden_Top(
//////////// CLOCK //////////
input ADC_CLK_10,
input MAX10_CLK1_50,
input MAX10_CLK2_50,
//////////// SDRAM //////////
output [12:0] DRAM_ADDR,
output [1:0] DRAM_BA,
output DRAM_CAS_N,
output DRAM_CKE,
output DRAM_CLK,
output DRAM_CS_N,
inout [15:0] DRAM_DQ,
output DRAM_LDQM,
output DRAM_RAS_N,
output DRAM_UDQM,
output DRAM_WE_N,
//////////// SEG7 //////////
output [7:0] HEX0,
output [7:0] HEX1,
output [7:0] HEX2,
output [7:0] HEX3,
output [7:0] HEX4,
output [7:0] HEX5,
//////////// KEY //////////
input [1:0] KEY,
//////////// LED //////////
output [9:0] LEDR,
//////////// SW //////////
input [9:0] SW,
//////////// VGA //////////
output [3:0] VGA_B,
output [3:0] VGA_G,
output VGA_HS,
output [3:0] VGA_R,
output VGA_VS,
//////////// Accelerometer //////////
output GSENSOR_CS_N,
input [2:1] GSENSOR_INT,
output GSENSOR_SCLK,
inout GSENSOR_SDI,
inout GSENSOR_SDO,
//////////// Arduino //////////
inout [15:0] ARDUINO_IO,
inout ARDUINO_RESET_N,
//////////// GPIO, GPIO connect to GPIO Default //////////
inout [35:0] GPIO
// REG/WIRE declarations
// Structural coding
endmodule
