YigalB1
1 year agoDE10 Lite setting pins from VErilog RTL
In my design, the GPIOs need to be used to connect to external host (Raspberry PI (aka RPI) in this case). The GPIOs connector of the DE10 lite will be connected to the RPI connector. Some are inp...
- 1 year ago
Just edit the top-level. And you need to give unique names to inputs vs. outputs (GPIO_IN vs. GPIO_OUT perhaps).
RichardT_altera
1 year agoPin assignment is not possible through RTL.
You need to use 'set_location_assignment' in the .qsf file.
Check the User Guide below for further details.
Alternatively, you could use the Pin Planner tool by go to Assignments > Pin Planner.
Richard Tan
