Fred_Barkins's avatar
Fred_Barkins
7 months ago
DE1-SoC project compiles, but board programming fails 42% through
When programming the board reaches 42%, I get the following error:
Info (209017): Device 2 contains JTAG ID code 0x02D120DD
Error (209040): Can't access JTAG chain
Error (209015): Can't configure device. Expected JTAG ID code 0x02D120DD for device 2, but found JTAG ID code 0x00000000. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
 I manage to program it with other designs, so it shouldn't be a physical problem.
This is considering a fairly basic project. Here's the platform designer layout:
Files in the project are only:
  1. The auto generated .qip file,
  2.  And a top module:
module DE1_SoC_Computer (
ports list);
declarations
// From Qsys
Computer_System The_System (
.sys_sdram_pll_0_ref_clk_clk (CLOCK_50),
.sys_sdram_pll_0_ref_reset_reset (KEY[0]),
.sys_sdram_pll_0_sdram_clk_clk (DRAM_CLK),
.new_sdram_controller_0_wire_addr (DRAM_ADDR), // new_sdram_controller_0_wire.addr
.new_sdram_controller_0_wire_ba (DRAM_BA), // .ba
.new_sdram_controller_0_wire_cas_n (DRAM_CAS_N), // .cas_n
.new_sdram_controller_0_wire_cke (DRAM_CKE), // .cke
.new_sdram_controller_0_wire_cs_n (DRAM_CS_N), // .cs_n
.new_sdram_controller_0_wire_dq (DRAM_DQ), // .dq
.new_sdram_controller_0_wire_dqm ({DRAM_UDQM,DRAM_LDQM}),
.new_sdram_controller_0_wire_ras_n (DRAM_RAS_N), // .ras_n
.new_sdram_controller_0_wire_we_n (DRAM_WE_N), // .we_n
.fifo_0_out_valid (fifo_valid), // fifo_0_out.valid
.fifo_0_out_data (fifo_data), // .data
.fifo_0_out_ready (fifo_ready), // .ready
.fifo_0_out_channel (), // .channel
.fifo_0_out_error (), // .error
.fifo_0_out_startofpacket (fifo_sop), // .startofpacket
.fifo_0_out_endofpacket (fifo_eop), // .endofpacket
.fifo_0_out_empty (fifo_empty), // .empty
.mm_bridge_0_s0_waitrequest (mm_waitrequest), // mm_bridge_0_s0.waitrequest
.mm_bridge_0_s0_readdata (mm_readdata), // .readdata
.mm_bridge_0_s0_readdatavalid (mm_readdatavalid), // .readdatavalid
.mm_bridge_0_s0_burstcount (mm_burstcount), // .burstcount
.mm_bridge_0_s0_writedata (mm_writedata), // .writedata
.mm_bridge_0_s0_address (mm_address), // .address
.mm_bridge_0_s0_write (mm_write), // .write
.mm_bridge_0_s0_read (mm_read), // .read
.mm_bridge_0_s0_byteenable (mm_byteenable), // .byteenable
.mm_bridge_0_s0_debugaccess (mm_debugaccess), // .debugaccess
// HPS DDR3
.hps_0_ddr_mem_a (HPS_DDR3_ADDR),
.hps_0_ddr_mem_ba (HPS_DDR3_BA),
.hps_0_ddr_mem_ck (HPS_DDR3_CK_P),
.hps_0_ddr_mem_ck_n (HPS_DDR3_CK_N),
.hps_0_ddr_mem_cke (HPS_DDR3_CKE),
.hps_0_ddr_mem_cs_n (HPS_DDR3_CS_N),
.hps_0_ddr_mem_ras_n (HPS_DDR3_RAS_N),
.hps_0_ddr_mem_cas_n (HPS_DDR3_CAS_N),
.hps_0_ddr_mem_we_n (HPS_DDR3_WE_N),
.hps_0_ddr_mem_reset_n (HPS_DDR3_RESET_N),
.hps_0_ddr_mem_dq (HPS_DDR3_DQ),
.hps_0_ddr_mem_dqs (HPS_DDR3_DQS_P),
.hps_0_ddr_mem_dqs_n (HPS_DDR3_DQS_N),
.hps_0_ddr_mem_odt (HPS_DDR3_ODT),
.hps_0_ddr_mem_dm (HPS_DDR3_DM),
.hps_0_ddr_oct_rzqin (HPS_DDR3_RZQ),
// HPS Peripherals (Ethernet, USB, etc.)
.hps_0_hps_io_hps_io_emac1_inst_TX_CLK (HPS_ENET_GTX_CLK),
.hps_0_hps_io_hps_io_emac1_inst_TXD0 (HPS_ENET_TX_DATA[0]),
.hps_0_hps_io_hps_io_emac1_inst_TXD1 (HPS_ENET_TX_DATA[1]),
.hps_0_hps_io_hps_io_emac1_inst_TXD2 (HPS_ENET_TX_DATA[2]),
.hps_0_hps_io_hps_io_emac1_inst_TXD3 (HPS_ENET_TX_DATA[3]),
.hps_0_hps_io_hps_io_emac1_inst_RXD0 (HPS_ENET_RX_DATA[0]),
.hps_0_hps_io_hps_io_emac1_inst_MDIO (HPS_ENET_MDIO),
.hps_0_hps_io_hps_io_emac1_inst_MDC (HPS_ENET_MDC),
.hps_0_hps_io_hps_io_emac1_inst_RX_CTL (HPS_ENET_RX_DV),
.hps_0_hps_io_hps_io_emac1_inst_TX_CTL (HPS_ENET_TX_EN),
.hps_0_hps_io_hps_io_emac1_inst_RX_CLK (HPS_ENET_RX_CLK),
.hps_0_hps_io_hps_io_emac1_inst_RXD1 (HPS_ENET_RX_DATA[1]),
.hps_0_hps_io_hps_io_emac1_inst_RXD2 (HPS_ENET_RX_DATA[2]),
.hps_0_hps_io_hps_io_emac1_inst_RXD3 (HPS_ENET_RX_DATA[3]),
.hps_0_hps_io_hps_io_qspi_inst_IO0 (HPS_FLASH_DATA[0]),
.hps_0_hps_io_hps_io_qspi_inst_IO1 (HPS_FLASH_DATA[1]),
.hps_0_hps_io_hps_io_qspi_inst_IO2 (HPS_FLASH_DATA[2]),
.hps_0_hps_io_hps_io_qspi_inst_IO3 (HPS_FLASH_DATA[3]),
.hps_0_hps_io_hps_io_qspi_inst_SS0 (HPS_FLASH_NCSO),
.hps_0_hps_io_hps_io_qspi_inst_CLK (HPS_FLASH_DCLK),
.hps_0_hps_io_hps_io_sdio_inst_CMD (HPS_SD_CMD),
.hps_0_hps_io_hps_io_sdio_inst_D0 (HPS_SD_DATA[0]),
.hps_0_hps_io_hps_io_sdio_inst_D1 (HPS_SD_DATA[1]),
.hps_0_hps_io_hps_io_sdio_inst_CLK (HPS_SD_CLK),
.hps_0_hps_io_hps_io_sdio_inst_D2 (HPS_SD_DATA[2]),
.hps_0_hps_io_hps_io_sdio_inst_D3 (HPS_SD_DATA[3]),
.hps_0_hps_io_hps_io_usb1_inst_D0 (HPS_USB_DATA[0]),
.hps_0_hps_io_hps_io_usb1_inst_D1 (HPS_USB_DATA[1]),
.hps_0_hps_io_hps_io_usb1_inst_D2 (HPS_USB_DATA[2]),
.hps_0_hps_io_hps_io_usb1_inst_D3 (HPS_USB_DATA[3]),
.hps_0_hps_io_hps_io_usb1_inst_D4 (HPS_USB_DATA[4]),
.hps_0_hps_io_hps_io_usb1_inst_D5 (HPS_USB_DATA[5]),
.hps_0_hps_io_hps_io_usb1_inst_D6 (HPS_USB_DATA[6]),
.hps_0_hps_io_hps_io_usb1_inst_D7 (HPS_USB_DATA[7]),
.hps_0_hps_io_hps_io_usb1_inst_CLK (HPS_USB_CLKOUT),
.hps_0_hps_io_hps_io_usb1_inst_STP (HPS_USB_STP),
.hps_0_hps_io_hps_io_usb1_inst_DIR (HPS_USB_DIR),
.hps_0_hps_io_hps_io_usb1_inst_NXT (HPS_USB_NXT),
.hps_0_hps_io_hps_io_uart0_inst_RX (HPS_UART_RX),
.hps_0_hps_io_hps_io_uart0_inst_TX (HPS_UART_TX)
multi_tile_solver solver_inst (
.clock (CLOCK_50),
.reset (KEY[0]),
.in_data (fifo_data),
.in_valid (fifo_valid),
.in_end_of_stream (fifo_eop),
.in_ready (fifo_ready),
.out_data (mm_writedata),
.out_addr (mm_address), // The solver keeps its full 32-bit view
.out_write_en (mm_write),
.out_ack (solver_ack)
endmodule // end top level
The Platform Designer auto-generated Comuter_System.v has the ports list:
module Computer_System (
output wire fifo_0_out_valid, // fifo_0_out.valid
output wire [31:0] fifo_0_out_data, // .data
output wire [7:0] fifo_0_out_channel, // .channel
output wire [7:0] fifo_0_out_error, // .error
output wire fifo_0_out_startofpacket, // .startofpacket
output wire fifo_0_out_endofpacket, // .endofpacket
output wire [1:0] fifo_0_out_empty, // .empty
input wire fifo_0_out_ready, // .ready
output wire [12:0] hps_0_ddr_mem_a, // hps_0_ddr.mem_a
output wire [2:0] hps_0_ddr_mem_ba, // .mem_ba
output wire hps_0_ddr_mem_ck, // .mem_ck
output wire hps_0_ddr_mem_ck_n, // .mem_ck_n
output wire hps_0_ddr_mem_cke, // .mem_cke
output wire hps_0_ddr_mem_cs_n, // .mem_cs_n
output wire hps_0_ddr_mem_ras_n, // .mem_ras_n
output wire hps_0_ddr_mem_cas_n, // .mem_cas_n
output wire hps_0_ddr_mem_we_n, // .mem_we_n
output wire hps_0_ddr_mem_reset_n, // .mem_reset_n
inout wire [7:0] hps_0_ddr_mem_dq, // .mem_dq
inout wire hps_0_ddr_mem_dqs, // .mem_dqs
inout wire hps_0_ddr_mem_dqs_n, // .mem_dqs_n
output wire hps_0_ddr_mem_odt, // .mem_odt
output wire hps_0_ddr_mem_dm, // .mem_dm
input wire hps_0_ddr_oct_rzqin, // .oct_rzqin
output wire hps_0_hps_io_hps_io_emac1_inst_TX_CLK, // hps_0_hps_io.hps_io_emac1_inst_TX_CLK
output wire hps_0_hps_io_hps_io_emac1_inst_TXD0, // .hps_io_emac1_inst_TXD0
output wire hps_0_hps_io_hps_io_emac1_inst_TXD1, // .hps_io_emac1_inst_TXD1
output wire hps_0_hps_io_hps_io_emac1_inst_TXD2, // .hps_io_emac1_inst_TXD2
output wire hps_0_hps_io_hps_io_emac1_inst_TXD3, // .hps_io_emac1_inst_TXD3
input wire hps_0_hps_io_hps_io_emac1_inst_RXD0, // .hps_io_emac1_inst_RXD0
inout wire hps_0_hps_io_hps_io_emac1_inst_MDIO, // .hps_io_emac1_inst_MDIO
output wire hps_0_hps_io_hps_io_emac1_inst_MDC, // .hps_io_emac1_inst_MDC
input wire hps_0_hps_io_hps_io_emac1_inst_RX_CTL, // .hps_io_emac1_inst_RX_CTL
output wire hps_0_hps_io_hps_io_emac1_inst_TX_CTL, // .hps_io_emac1_inst_TX_CTL
input wire hps_0_hps_io_hps_io_emac1_inst_RX_CLK, // .hps_io_emac1_inst_RX_CLK
input wire hps_0_hps_io_hps_io_emac1_inst_RXD1, // .hps_io_emac1_inst_RXD1
input wire hps_0_hps_io_hps_io_emac1_inst_RXD2, // .hps_io_emac1_inst_RXD2
input wire hps_0_hps_io_hps_io_emac1_inst_RXD3, // .hps_io_emac1_inst_RXD3
inout wire hps_0_hps_io_hps_io_qspi_inst_IO0, // .hps_io_qspi_inst_IO0
inout wire hps_0_hps_io_hps_io_qspi_inst_IO1, // .hps_io_qspi_inst_IO1
inout wire hps_0_hps_io_hps_io_qspi_inst_IO2, // .hps_io_qspi_inst_IO2
inout wire hps_0_hps_io_hps_io_qspi_inst_IO3, // .hps_io_qspi_inst_IO3
output wire hps_0_hps_io_hps_io_qspi_inst_SS0, // .hps_io_qspi_inst_SS0
output wire hps_0_hps_io_hps_io_qspi_inst_CLK, // .hps_io_qspi_inst_CLK
inout wire hps_0_hps_io_hps_io_sdio_inst_CMD, // .hps_io_sdio_inst_CMD
inout wire hps_0_hps_io_hps_io_sdio_inst_D0, // .hps_io_sdio_inst_D0
inout wire hps_0_hps_io_hps_io_sdio_inst_D1, // .hps_io_sdio_inst_D1
output wire hps_0_hps_io_hps_io_sdio_inst_CLK, // .hps_io_sdio_inst_CLK
inout wire hps_0_hps_io_hps_io_sdio_inst_D2, // .hps_io_sdio_inst_D2
inout wire hps_0_hps_io_hps_io_sdio_inst_D3, // .hps_io_sdio_inst_D3
inout wire hps_0_hps_io_hps_io_usb1_inst_D0, // .hps_io_usb1_inst_D0
inout wire hps_0_hps_io_hps_io_usb1_inst_D1, // .hps_io_usb1_inst_D1
inout wire hps_0_hps_io_hps_io_usb1_inst_D2, // .hps_io_usb1_inst_D2
inout wire hps_0_hps_io_hps_io_usb1_inst_D3, // .hps_io_usb1_inst_D3
inout wire hps_0_hps_io_hps_io_usb1_inst_D4, // .hps_io_usb1_inst_D4
inout wire hps_0_hps_io_hps_io_usb1_inst_D5, // .hps_io_usb1_inst_D5
inout wire hps_0_hps_io_hps_io_usb1_inst_D6, // .hps_io_usb1_inst_D6
inout wire hps_0_hps_io_hps_io_usb1_inst_D7, // .hps_io_usb1_inst_D7
input wire hps_0_hps_io_hps_io_usb1_inst_CLK, // .hps_io_usb1_inst_CLK
output wire hps_0_hps_io_hps_io_usb1_inst_STP, // .hps_io_usb1_inst_STP
input wire hps_0_hps_io_hps_io_usb1_inst_DIR, // .hps_io_usb1_inst_DIR
input wire hps_0_hps_io_hps_io_usb1_inst_NXT, // .hps_io_usb1_inst_NXT
input wire hps_0_hps_io_hps_io_uart0_inst_RX, // .hps_io_uart0_inst_RX
output wire hps_0_hps_io_hps_io_uart0_inst_TX, // .hps_io_uart0_inst_TX
output wire mm_bridge_0_s0_waitrequest, // mm_bridge_0_s0.waitrequest
output wire [15:0] mm_bridge_0_s0_readdata, // .readdata
output wire mm_bridge_0_s0_readdatavalid, // .readdatavalid
input wire [0:0] mm_bridge_0_s0_burstcount, // .burstcount
input wire [15:0] mm_bridge_0_s0_writedata, // .writedata
input wire [31:0] mm_bridge_0_s0_address, // .address
input wire mm_bridge_0_s0_write, // .write
input wire mm_bridge_0_s0_read, // .read
input wire [1:0] mm_bridge_0_s0_byteenable, // .byteenable
input wire mm_bridge_0_s0_debugaccess, // .debugaccess
output wire [12:0] new_sdram_controller_0_wire_addr, // new_sdram_controller_0_wire.addr
output wire [1:0] new_sdram_controller_0_wire_ba, // .ba
output wire new_sdram_controller_0_wire_cas_n, // .cas_n
output wire new_sdram_controller_0_wire_cke, // .cke
output wire new_sdram_controller_0_wire_cs_n, // .cs_n
inout wire [15:0] new_sdram_controller_0_wire_dq, // .dq
output wire [1:0] new_sdram_controller_0_wire_dqm, // .dqm
output wire new_sdram_controller_0_wire_ras_n, // .ras_n
output wire new_sdram_controller_0_wire_we_n, // .we_n
input wire sys_sdram_pll_0_ref_clk_clk, // sys_sdram_pll_0_ref_clk.clk
input wire sys_sdram_pll_0_ref_reset_reset, // sys_sdram_pll_0_ref_reset.reset
output wire sys_sdram_pll_0_sdram_clk_clk // sys_sdram_pll_0_sdram_clk.clk
What is causing this failure?
  • FakhrulA_altera's avatar
    FakhrulA_altera
    As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Altera experts. Otherwise, community users will continue to assist you here. Thank you.
