Fred_Barkins
7 months agoDE1-SoC project compiles, but board programming fails 42% through
Hello, When programming the board reaches 42%, I get the following error: Info (209017): Device 2 contains JTAG ID code 0x02D120DD Error (209040): Can't access JTAG chain Error (209015): Can't co...
FakhrulA_altera
6 months agoHi Fred_Barkins,
There might be a solution to a similar case here:
https://www.reddit.com/r/FPGA/comments/46sya8/quartus_error_programming_device/
The suggested solution is to use the Terasic DE1-SoC System Builder, which helps ensure all your settings are correct.
Could you please take a look?
Fakhrul
