bsher's avatar
bsher
9 months ago
DDR5 PHY-only IP availability for Agilex 7 M-Series
I am seeking a DDR5 PHY-only IP for the Agilex 7 M-series. I came across an older thread Is DDR5 phy-only IP available? | Altera Community that mentioned plans to release PHY-only support for the EMIF IP on Agilex 7 M-series.
Could you confirm if this plan is still active? Has there been any update on the availability of DDR5 PHY-only mode?
Thank you.
  • Hi bsher,
    "Could you confirm if this plan is still active? Has there been any update on the availability of DDR5 PHY-only mode?"
    • Unfortunately the PHY-Only mode is not available in Agilex 7 M-series.
    The user can use PHY-Lite IP to implement the DDR5 PHY-Only and used user own memory controller to connect with the IP.
    Adzim
1 Reply
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi bsher,
    Adzim
