16 years ago
DDR2-SDRAM High performance controller
Hi All,
I am currently using the DDR2-SDRAM High performance controller on Quartus II 8.0. I assume that the controller had been successfully generated. but i can not effectively test the the system as the example driver always hangs.
I have noticed using signal tap that the signal mem_local_rdata_valid never got asserted by the controller.
Does anyone have experience with this?
Test conditions:
Stratix II EPS30F67
Micron's DDR2 MT47H16M16
Quartus II 8.0
Yems
    Hi Yems,
    I am not sure why rdata_valid signal is not being asserted. Altera has a very good simulation model that runs in ModelSim. I tested my design first with the simulation before compiling it for the hardware. I would suggest you to try the simulation and see if you get the same result. I have done most of my compilation/simulation with 9.1, so I am not sure if 8.0 has an issue with DDR2 controller.
    Kumaran
