17 years agoddr2_auto_verify_timing
Hi all,
I am using Altera' DDR2 IP core with feedback clock option and I am encountering one problem: The auto_verify_ddr_timing.tcl script could not be done. error: ddr timing cannot be verified until project has been successfully compiled.error: evaluation of tcl script auto_verify_ddr_timing.tcl unsuccessful
I found the following information in DDR2_IP_extraction_log.txt: error: evaluation of tcl script c:/altera/8.0/ip/ddr_ddr2_sdram/system_timing/tan_arg_dqsfbc.tcl unsuccessful
error: quartus ii classic timing analyzer was unsuccessful. 1 error, 2 warnings
error: peak virtual memory: 208 megabytes
error: processing ended: thu jun 04 12:03:50 2009
error: elapsed time: 00:00:21
error: total cpu time (on all processors): 00:00:21
assertion failed( $errmsg=="" ) $errmsg:{moving paennode failed: wanted doing_rd_delayed$ on node (reg) ddr2_ip dr2_ip_ddr_sdram|ddr2_ip_auk_ddr_sdram dr2_ip_auk_ddr_sdram_inst|ddr2_ip_auk_ddr_datapath:ddr_io|ddr2_ip_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|dq_enable_reset[0]
- asynch to soft_reset_reg2_n~clkctrl ic(0.679 ns) + cell(0.363 ns)
- synch to ddr2_ip:r2_ip_ddr_sdram|ddr2_ip_auk_ddr_sdram:\r2_ip_auk_ddr_sdram_inst|ddr2_ip_auk_ddr_datapath:ddr_io|ddr2_ip_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|dq_enable_reset[0]~feeder ic(0.000 ns) + cell(0.097 ns)
- clock to ddr_pll_fb_stratixii:g_stratixpll_ddr_fedback_pll_inst|altpll:altpll_component|_clk1~clkctrl ic(0.659 ns) + cell(0.378 ns)
- fanout to ddr2_ip-> r2_ip_ddr_sdram|ddr2_ip_auk_ddr_sdram->r2_ip_auk_ddr_sdram_inst|ddr2_ip_auk_ddr_datapath:ddr_io|ddr2_ip_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|dqs_io~regout reg ic(0.232 ns) + cell(0.372 ns)
\ located at lcff_x77_y50_n3}
assertion failed(false) delay unreasonable $k:sysclk_postctrl $v:0
moving paennode failed: wanted doing_rd_delayed$ on node (reg) ddr2_ip->r2_ip_ddr_sdram|ddr2_ip_auk_ddr_sdram->r2_ip_auk_ddr_sdram_inst|ddr2_ip_auk_ddr_datapath:ddr_io|ddr2_ip_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|dq_enable_reset[0]
- synch to ddr2_ip->r2_ip_ddr_sdram|ddr2_ip_auk_ddr_sdram->r2_ip_auk_ddr_sdram_inst|ddr2_ip_auk_ddr_datapath:ddr_io|ddr2_ip_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|dq_enable_reset[0]~feeder ic(0.000 ns) + cell(0.097 ns)
- fanout to ddr2_ip->r2_ip_ddr_sdram|ddr2_ip_auk_ddr_sdram->r2_ip_auk_ddr_sdram_inst|ddr2_ip_auk_ddr_datapath:ddr_io|ddr2_ip_auk_ddr_dqs_group:\g_datapath:0:g_ddr_io|dqs_io~regout reg ic(0.232 ns) + cell(0.372 ns)
while executing
"error "$errmsg""
(procedure "::ddr::dqsfbc::extract_s2_paths" line 162)
invoked from within
"::ddr::dqsfbc::extract_s2_paths $node $variation_name extract_debug $settings_array(enable_postamble) "
invoked from within
"set res [::ddr::dqsfbc::extract_s2_paths $node $variation_name extract_debug $settings_array(enable_postamble) ]"
invoked from within
"foreach_in_collection node [get_timing_nodes -type pin] {
set node_name [get_timing_node_info -info name $node]
set res [::ddr::dqsfbc::extract_s2_pat..."
("foreach" body line 14)
invoked from within
"foreach pvt {fast slow} {
set dq_pin_list
[list]
set tco_min ""
set tco_max ""
set pincount 0
set clock_pins_found 0
catch { delete_timing_netlist }
i..."
invoked from within
"time {
set margins(capture) ""
set margins(resync1) ""
set margins(resync2) ""
set margins(postambleen) ""
set margins(postamble1) ""
set margins(post..."
invoked from within
"set t [time {
set margi..."
(file "c:/altera/8.0/ip/ddr_ddr2_sdram/system_timing/tan_arg_dqsfbc.tcl" line 156)
------------------------------------------------ I used the sample driver of IP not mine. The proplem didn't occur while feedback clock is turn off. Could anyone help me? Thanks and best regards,
1 Reply
Have you regenerated the Megacore using the same version of Quartus that you are compiling with?
Going back a step, is there a good reason to use fedback clock mode? It is a lot of trouble, and doesn't give a massive performance improvement.
