16 years agoDDR input without DPA in Arria II GX
Hello I am using arria ii gx to communicate with a high speed device. The device is sending DDR data, data with a data clock, dclk. dclk and data are source synchronous. I need to capture the d...
16 years agoFriends,
I have instantiated an external PLL whose output clocks drive an alt_lvds instance which has dpa enabled. I am slightly confused about the operation of this circuit; is the dpa going to generate 8 phases from its input clock (output of external PLL) and choose the best one? On top of dpa ckt generating its own 8 phases, I can also adjust the phase of PLL output clock by varying PLL settings? Can I use "rx_dpll_enable" at run time to dynamcially enable/diable dpa circuitry? "rx_dpll_enable" is mentioned in Arria literature but not in Arria II GX literature. Thanks for your guidance!
