16 years agoDDR input without DPA in Arria II GX
Hello I am using arria ii gx to communicate with a high speed device. The device is sending DDR data, data with a data clock, dclk. dclk and data are source synchronous. I need to capture the d...
16 years agoJake,
Its not that nothing is known. For each board, the frequency of the clock coming in as well as its relationship to the data bus is known; its just that both of these are changing from board to board. To create a separate bitstream for each board is not feasible, so my goal is to build a design in which I can vary the skew between data and clock before it gets sampled by the input DDR cells. Hit and trial by user (granted an ability to play around with the skew adjustment), until data is correctly sampled, is acceptable. Thank you very much for your kind and generous help!
