12 years agoDDR Input Same Edge vs Opposite Edge transfer
Background 12 bit Serialized DDR data stream coming into the FPGA via LVDS at 960Mbps. 480MHz bitclock along with data channels being sent. 80Mhz frame clock too. I was wondering if it matters in a long data stream if we constrain the design on same edge transfer vs opposite edge transfer. If it is wrong, the first and last sample will be long. But in a continuous stream it shouldn't matter? Should it? Opposite edge transfer is better for timing constraints and eases timing. I can't seem to figure a way to simulate it. Can't get gate level simulations to run on Model Sim and verilog is functionally the same.. Comments and feedback welcome. Thanks Zubair4 Replies
--- Quote Start --- Hi, Background 12 bit Serialized DDR data stream coming into the FPGA via LVDS at 960Mbps. 480MHz bitclock along with data channels being sent. 80Mhz frame clock too. I was wondering if it matters in a long data stream if we constrain the design on same edge transfer vs opposite edge transfer. If it is wrong, the first and last sample will be long. But in a continuous stream it shouldn't matter? Should it? Opposite edge transfer is better for timing constraints and eases timing. I can't seem to figure a way to simulate it. Can't get gate level simulations to run on Model Sim and verilog is functionally the same.. Comments and feedback welcome. Thanks Zubair --- Quote End --- My understanding is that the data stream once it arrives for latch it does not matter which edge captures first since there is no memory of how or from which edge data was launched. The important thing is to realise that the default settings are too restrictive and need be relaxed across edges and it then depends on the following possibilities: No PLL, or PLL set to 0 or < 0 => edge aligned input defaults PLL set to > 0 => centre aligned input defaults. User can then choose settings for either: Same edge capture Opposite edge capture thus there will be four sets of possibilities: Edge aligned input, same edge capture Edge aligned input, opposite edge capture centre aligned input, same edge capture centre aligned input, opposite edge capture Exceptions(multicycle or false paths) vary accordingly. edit: The only issue that I see is if input offset values from rise edge differ from those of falling edge in which case the tool needs to identify the two separately and apply worst case. - Altera_Forum
The data stream once latched by Bitclock at 480MHz is separated into 12 bit data using the slow 80MHz frame clock.
So Centre aligned input same/opposite edge capture should work. Is there a way to simulate this? For some reason, my model-sim gate level simulation doesn't work. Says the design unit not found in library. I could run functional simulations properly using the same setup.. - Altera_Forum
--- Quote Start --- The data stream once latched by Bitclock at 480MHz is separated into 12 bit data using the slow 80MHz frame clock. So Centre aligned input same/opposite edge capture should work. --- Quote End --- The 80MHz clk is irelevant to ddr interface. We are talking about io paths not 480 to 80 path --- Quote Start --- Is there a way to simulate this? For some reason, my model-sim gate level simulation doesn't work. Says the design unit not found in library. I could run functional simulations properly using the same setup.. --- Quote End --- check you have installed those libraries or try modelsim directly not through quartus launch. You can also try quartus simulator possibly older versions. - Altera_Forum
I needed to add all my design files along with the testbench file in the EDA Simulation settings. Not adding worked for rtl simulation. Not gate level.
I've simulated it and it seems to be working according to my eye.. Thanks ZubairLK
