12 years agoDDR Input Same Edge vs Opposite Edge transfer
Hi, Background 12 bit Serialized DDR data stream coming into the FPGA via LVDS at 960Mbps. 480MHz bitclock along with data channels being sent. 80Mhz frame clock too. I was wondering ...
12 years agoThe data stream once latched by Bitclock at 480MHz is separated into 12 bit data using the slow 80MHz frame clock.
So Centre aligned input same/opposite edge capture should work. Is there a way to simulate this? For some reason, my model-sim gate level simulation doesn't work. Says the design unit not found in library. I could run functional simulations properly using the same setup..
