Hi Eugene,
Just a few questions on your code.
On this section here:
if(!source_empty && !mm_bridge_2_s0_waitrequest) begin
mm_bridge_2_s0_read<=1;
mm_bridge_2_s0_address<=fifo_read_offset|{5'b0,fifo_read_address};
fifo_read_address<=fifo_read_address+4;
source_empty<=...;
end
else if(!mm_bridge_2_s0_waitrequest)
mm_bridge_2_s0_read<=0;
if(mm_bridge_2_s0_readdatavalid && !core_full)
... <= mm_bridge_2_s0_readdata;
else
I am pretty lost on what this read section here is for. I don't think I need to do any reads so for now I am commenting it out assuming that it is regarding some specific act you are trying to do. I'm not exactly sure. And I do not know what source_empty or core_full are either.
I am pretty sure I understand the write section found here:
if(core_readdatavalid & !mm_bridge_0_s0_waitrequest) begin
mm_bridge_0_s0_write<=1;
mm_bridge_0_s0_writedata <= data_input;
mm_bridge_0_s0_address<=fifo_write_offset|{5'b0,fifo_write_address};
fifo_write_address<=fifo_write_address+4;
end
else if(!mm_bridge_0_s0_waitrequest)
mm_bridge_0_s0_write<=0;
Except I am not sure what core_readdatavalid is for, I'm assuming though that it would help if I understood what the read section before that is for?
Given that I followed along with everything above correctly, I modified it into my module here:
module send_to_hps(data_input, mm_bridge_0_s0_waitrequest, mm_bridge_0_s0_writedata, mm_bridge_0_s0_address, mm_bridge_0_s0_write);
//Inputs
input data_input;
input mm_bridge_0_s0_waitrequest;
//Wires
//wire mm_bridge_0_s0_waitrequest;
//wire mm_bridge_0_s0_readdata;
//wire mm_bridge_0_s0_readdatavalid;
//Outputs
output mm_bridge_0_s0_writedata;
output mm_bridge_0_s0_write;
output mm_bridge_0_s0_address;
//Registers
reg mm_bridge_0_s0_writedata=0;
reg mm_bridge_0_s0_address=0;
reg mm_bridge_0_s0_write=0;
//reg mm_bridge_0_s0_read=0;
//reg fifo_read_offset= 32'h20000000;
//reg fifo_read_address=0;
reg fifo_write_offset=32'h28000000;
reg fifo_write_address=0;
/*if(!source_empty && !mm_bridge_2_s0_waitrequest)
begin
source_empty<=...;
end
else
mm_bridge_2_s0_read<=0;*/
always @ (data_input)
begin
if(/*core_readdatavalid &&*/ !mm_bridge_0_s0_waitrequest)
begin
fifo_write_address<=fifo_write_address+16;
end
end
endmodule
The Inputs/Outputs to this module are all connected to the MM_Bridge for the HPS except for data_input. So I think that's correct.
I have two final questions:
One where did you come to the address 32'h28000000 to start writing at?
And two would I then try to read from that address in Linux using the C code something like this:
char* toBinary(int value, int precision){ static char buf = {0};
buf = 0;
for(; value && precision ; --precision, value /= 2) {
buf = "01";
for(; precision ; --precision){
buf = '0';
return &buf;
int main(int argc, char *argv) {
if (argc != 3) {
printf("usage: %s <address> <#bytes>\n",argv);
return 0;
off_t offset = strtoul(argv, NULL, 0);
size_t len = strtoul(argv, NULL, 0);
// Truncate offset to a multiple of the page size, or mmap will fail.
size_t pagesize = sysconf(_SC_PAGE_SIZE);
off_t page_base = (offset / pagesize) * pagesize;
off_t page_offset = offset - page_base;
int fd = open("/dev/mem", O_SYNC);
unsigned char *mem = mmap(NULL, page_offset + len, PROT_READ | PROT_WRITE, MAP_PRIVATE, fd, page_base);
if (mem == MAP_FAILED) {
perror("Can't map memory");
return -1;
size_t i;
for (i = 0; i < len; i++){
int temp = (int)mem;
printf("%s ",toBinary(temp,8));
if((i + 1) % 16 == 0 && i != len - 1){
printf("\n");
printf("\n");
if(temp >= 32 && temp <= 126){
printf("%c",temp);
}else{
printf("_");
if((i + 1) % 143 == 0 && i != len - 1){
printf("\n");
printf("\n");
return 0;
Where address would be 28000000 and bytes in my case would be 16 for 128 bits?
