8 years agoData Transfer from FPGA-to-HPS
Hi, I am very new to the Altera FPGA suite (and FPGAs in general), and was looking to get some advice on how to transfer data from the FPGA to the HPS. I've done fair amount of research, but I ...
8 years agoHi Eugene,
Just a few questions on your code. On this section here:if(!source_empty && !mm_bridge_2_s0_waitrequest) begin
mm_bridge_2_s0_read<=1;
mm_bridge_2_s0_address<=fifo_read_offset|{5'b0,fifo_read_address};
fifo_read_address<=fifo_read_address+4;
source_empty<=...;
end
else if(!mm_bridge_2_s0_waitrequest)
mm_bridge_2_s0_read<=0;
if(mm_bridge_2_s0_readdatavalid && !core_full)
... <= mm_bridge_2_s0_readdata;
else
mm_bridge_2_s0_read<=0; I am pretty lost on what this read section here is for. I don't think I need to do any reads so for now I am commenting it out assuming that it is regarding some specific act you are trying to do. I'm not exactly sure. And I do not know what source_empty or core_full are either. I am pretty sure I understand the write section found here: if(core_readdatavalid & !mm_bridge_0_s0_waitrequest) begin
mm_bridge_0_s0_write<=1;
mm_bridge_0_s0_writedata <= data_input;
mm_bridge_0_s0_address<=fifo_write_offset|{5'b0,fifo_write_address};
fifo_write_address<=fifo_write_address+4;
end
else if(!mm_bridge_0_s0_waitrequest)
mm_bridge_0_s0_write<=0; Except I am not sure what core_readdatavalid is for, I'm assuming though that it would help if I understood what the read section before that is for? Given that I followed along with everything above correctly, I modified it into my module here: module send_to_hps(data_input, mm_bridge_0_s0_waitrequest, mm_bridge_0_s0_writedata, mm_bridge_0_s0_address, mm_bridge_0_s0_write);
//Inputs
input data_input;
input mm_bridge_0_s0_waitrequest;
//Wires
//wire mm_bridge_0_s0_waitrequest;
//wire mm_bridge_0_s0_readdata;
//wire mm_bridge_0_s0_readdatavalid;
//Outputs
output mm_bridge_0_s0_writedata;
output mm_bridge_0_s0_write;
output mm_bridge_0_s0_address;
//Registers
reg mm_bridge_0_s0_writedata=0;
reg mm_bridge_0_s0_address=0;
reg mm_bridge_0_s0_write=0;
//reg mm_bridge_0_s0_read=0;
//reg fifo_read_offset= 32'h20000000;
//reg fifo_read_address=0;
reg fifo_write_offset=32'h28000000;
reg fifo_write_address=0;
/*if(!source_empty && !mm_bridge_2_s0_waitrequest)
begin
source_empty<=...;
end
else
mm_bridge_2_s0_read<=0;*/
always @ (data_input)
begin
if(/*core_readdatavalid &&*/ !mm_bridge_0_s0_waitrequest)
begin
fifo_write_address<=fifo_write_address+16;
end
end
endmodule The Inputs/Outputs to this module are all connected to the MM_Bridge for the HPS except for data_input. So I think that's correct. I have two final questions: One where did you come to the address 32'h28000000 to start writing at? And two would I then try to read from that address in Linux using the C code something like this: char* toBinary(int value, int precision){ static char buf = {0};
buf = 0;
for(; value && precision ; --precision, value /= 2) {
buf = "01";
for(; precision ; --precision){
buf = '0';
return &buf;
int main(int argc, char *argv) {
if (argc != 3) {
printf("usage: %s <address> <#bytes>\n",argv);
return 0;
off_t offset = strtoul(argv, NULL, 0);
size_t len = strtoul(argv, NULL, 0);
// Truncate offset to a multiple of the page size, or mmap will fail.
size_t pagesize = sysconf(_SC_PAGE_SIZE);
off_t page_base = (offset / pagesize) * pagesize;
off_t page_offset = offset - page_base;
int fd = open("/dev/mem", O_SYNC);
unsigned char *mem = mmap(NULL, page_offset + len, PROT_READ | PROT_WRITE, MAP_PRIVATE, fd, page_base);
if (mem == MAP_FAILED) {
perror("Can't map memory");
return -1;
size_t i;
for (i = 0; i < len; i++){
int temp = (int)mem;
printf("%s ",toBinary(temp,8));
if((i + 1) % 16 == 0 && i != len - 1){
printf("\n");
printf("\n");
if(temp >= 32 && temp <= 126){
printf("%c",temp);
}else{
printf("_");
if((i + 1) % 143 == 0 && i != len - 1){
printf("\n");
printf("\n");
return 0;
} Where address would be 28000000 and bytes in my case would be 16 for 128 bits?
