8 years agoData Transfer from FPGA-to-HPS
Hi, I am very new to the Altera FPGA suite (and FPGAs in general), and was looking to get some advice on how to transfer data from the FPGA to the HPS. I've done fair amount of research, but I ...
8 years agowire mm_bridge_2_s0_waitrequest;
wire mm_bridge_2_s0_readdata;
wire mm_bridge_2_s0_readdatavalid;
reg mm_bridge_2_s0_writedata=0;
reg mm_bridge_2_s0_address=0;
reg mm_bridge_2_s0_write=0;
reg mm_bridge_2_s0_read=0;
//reg mm_bridge_2_s0_read_requested=0;
//reg mm_bridge_2_s0_write_requested=0;
reg fifo_read_offset= 32'h20000000;
reg fifo_read_address=0;
reg fifo_write_offset=32'h28000000;
reg fifo_write_address=0;
if(!source_empty && !mm_bridge_2_s0_waitrequest)
begin
mm_bridge_2_s0_read<=1;
mm_bridge_2_s0_address<=fifo_read_offset|{5'b0,fifo_read_address};
fifo_read_address<=fifo_read_address+4;
source_empty<=...;
end
else if(!mm_bridge_2_s0_waitrequest)
mm_bridge_2_s0_read<=0;
if(mm_bridge_2_s0_readdatavalid && !core_full)
... <= mm_bridge_2_s0_readdata;
else
if(core_readdatavalid && !mm_bridge_2_s0_waitrequest)
begin
mm_bridge_2_s0_write<=1;
mm_bridge_2_s0_writedata <= ...;
mm_bridge_2_s0_address<=fifo_write_offset|{5'b0,fifo_write_address};
fifo_write_address<=fifo_write_address+4;
end
mm_bridge_2_s0_write<=0;
// FPGA->HPS access wires
.mm_bridge_2_s0_waitrequest(mm_bridge_2_s0_waitrequest), // mm_bridge_1_s0.waitrequest
.mm_bridge_2_s0_readdata(mm_bridge_2_s0_readdata), // .readdata
.mm_bridge_2_s0_readdatavalid(mm_bridge_2_s0_readdatavalid), // .readdatavalid
.mm_bridge_2_s0_burstcount(1'b1), // .burstcount
.mm_bridge_2_s0_writedata(mm_bridge_2_s0_writedata), // .writedata
.mm_bridge_2_s0_address(mm_bridge_2_s0_address), // .address
.mm_bridge_2_s0_write(mm_bridge_2_s0_write), // .write
.mm_bridge_2_s0_read(mm_bridge_2_s0_read), // .read
.mm_bridge_2_s0_byteenable(4'hf), // .byteenable
.mm_bridge_2_s0_debugaccess(1'b0), // .debugaccess
