8 years agoData Transfer from FPGA-to-HPS
Hi, I am very new to the Altera FPGA suite (and FPGAs in general), and was looking to get some advice on how to transfer data from the FPGA to the HPS. I've done fair amount of research, but I ...
8 years agocore_readdatavalid and core_full are signals from the part of my code that does the processing. source_empty signals the code to stop reading after a certain number of bytes has been read.
I am confused by your "always @ (data_input)". Either I misunderstand what you're trying to do, or this is wrong (or both). It should be "always @(posedge clk)" where clk is the clock that is associated with mm_bridge_0_s0. If the write succeeds (you come into the block, you have data to write, and mm_bridge_0_s0_waitrequest is low), you do whatever has to be done to replace data_input with the next value to write. I use the entire top 512M for transferring data in and out. 2000_0000 to 2800_0000 is input buffer (written by the HPS and read by the FPGA) and 2800_0000 onwards is the output buffer (written by the FPGA and read by the HPS). Yes, the resulting data should be visible to a code like that at address 2800_0000.
